  • 1 Votes - 5 Average
W220 wont start from ignition key
12-12-2017, 01:44 PM
helo,am working with w220 with M112 engine,the transmission control for this car was defective,i found new tcu but differ part no,and car is not starting from the key but when i start from the relay car start and shift fine than with old tcu.
can someone help me if i can bypass or do anything so that the car will start from ignition with new tcu
12-12-2017, 01:51 PM
RE: W220 wont start from ignition key
Make sure that the TCU is compatible. Did you scan the transmission module? Is it communicating normally? any codes? Also is it 7G tronic? If it is than you have to renew the TCU and do SCN coding + drive authorization.
 Thanks given by: ivannzowa
12-12-2017, 01:52 PM
Tcu not compartible,its 722.6
12-12-2017, 01:57 PM
(12-12-2017 01:52 PM)ivannzowa Wrote:  Tcu not compartible,its 722.6
Just get the right module, there is no programming involved on 722.6
12-12-2017, 02:00 PM
Sure,can you check part no for me...if i send vin
12-12-2017, 02:54 PM
(12-12-2017 02:00 PM)ivannzowa Wrote:  Sure,can you check part no for me...if i send vin
if u have old part wHy not just get number from that?
12-13-2017, 01:21 AM
EGS is not good. You mast have the part for your car.
12-14-2017, 02:32 AM
Here is VIN WDB2201672A452871,someone check for egs part numbers
06-08-2018, 05:31 PM
find another tcu
أرسلت بواسطة iPhone بإستخدام Tapatalk
  c200 w203 wont start Shawnp 10 704 07-15-2018 02:15 AM
Last Post: Mercerwin
  212 E63 pulling ignition timing way back/no power Duncansport 9 479 07-13-2018 06:00 AM
Last Post: tirex2k
Mercedes Benz MB ML W164 key wont turn after dead baterry kentrinite 4 469 07-12-2018 03:44 AM
Last Post: redangell
Mercedes Benz Mercedes B200 CDi wont go past 120kmph MafiaDON 4 379 07-09-2018 11:15 AM
Last Post: stachu121
  Xentry Das 12 2017 ignition detect error Sparks7766 1 337 07-09-2018 05:40 AM
Last Post: LORD
