W222 KLA problem
05-17-2018, 10:52 AM
Mercedes Benz W222 KLA problem
Hello guys !
I have problem with air condition in MB W222. At morning all working fine, but after some time air condition don't freezing. No have any errors in ECU. System is full. I tried change compressor and valve in system, update ECUs soft, but problem is present . Any ideas?!...
05-17-2018, 11:24 AM
RE: W222 KLA problem
Check the actual value for AC.
05-17-2018, 11:29 AM
All actual values in AC ECU is OK ! I check it first !
05-17-2018, 12:39 PM
Mercedes Benz RE: W222 KLA problem
(05-17-2018 11:29 AM)alex1972 Wrote:  All actual values in AC ECU is OK ! I check it first !
Dear Sir:
as you described information, i suggest to check the actual value of evaporator temp. sensor. As A/C system run a period, the system doesn't make cooling air anymore. possible causes are:
1. the temperature sensor detect actual temp not correct (a little higher with actual data) you can change it to make a experimental test. or you can adjust the lowest temp higher to 2 celsius degree in A/C module.
2. inspect A/C hose to locate whether anywhere frost
if i help you, please press"reputation"
05-17-2018, 08:47 PM
All sensor is in correct values .. A/C hoses are not frosting, hoses are warm ..
05-18-2018, 12:03 AM
does it happens only in auto mode?
if you choose max cooling the same?
Mercedes Comand/Audio antitheft codes all NTG
Mercedes Garmin Map Pilot Europe navi
Mercedes NTG5-5.5 Regio Software
05-18-2018, 12:21 AM
Yes, in auto mode and in max cooling all the same ..
05-18-2018, 12:23 AM
what are sensor temperatures
05-18-2018, 01:53 AM
Actual values all sensors is ok! About 18-22 °C , refrigerant pressure about 8-9 bar, but low pressure about 6 bar! About 900 mA is compressor current ..
  W222 remote boot lid not opening Dimss89 3 593 05-17-2018 12:53 PM
Last Post: benz001
Mercedes Benz W222 exchang transmission EEPROM date yuwei76 0 158 05-17-2018 12:06 AM
Last Post: yuwei76
  W222 Distronic ghost bawarek 2 234 05-14-2018 03:33 AM
Last Post: bawarek
Mercedes Benz MB W222 Air Balance retrofit mate11 2 453 05-09-2018 11:43 PM
Last Post: mate11
Mercedes Benz w639 apprehension F-KLA n_nikolaychuk 0 166 05-07-2018 06:18 AM
Last Post: n_nikolaychuk
