  • 4 Votes - 3.5 Average
Wrong JAVA Version EWAnet 2017 - EPC halts
01-20-2018, 12:16 PM (This post was last modified: 01-20-2018 12:17 PM by Starsearcher.)
Mercedes Benz Wrong JAVA Version EWAnet 2017 - EPC halts
I'm testing https://mhhauto.com/Thread-Xentry-OpenSh...onis-Image.
EPC/WIS won't start, because JAVA 9.0.1 (64bit) prevents it. I guess it must have been updated automatically or unnoticed.
What is the right Version for EWA Version 1.27.21.12 and where can I download? Must it be a 64 bit version for Windows 7/64 ultimate ?
Thanks in advance for your help.
I'm not a native speaker and therefore I ask for your indulgence Handshake
01-20-2018, 01:31 PM
RE: Wrong JAVA Version EWAnet 2017 - EPC halts
I have java 8 update 161 and working without problems. You can download from java.com
 Thanks given by: Starsearcher
01-20-2018, 01:47 PM
(01-20-2018 12:16 PM)Starsearcher Wrote:  I'm testing https://mhhauto.com/Thread-Xentry-OpenSh...onis-Image.
From my experience, you need the 32 bit version. I tried 64bit, and it didn't work.
Sent from my Nexus 5 using Tapatalk
01-20-2018, 02:29 PM
I use 64bit version windows 7 or 10 for all MB softwares.
01-20-2018, 03:06 PM (This post was last modified: 01-20-2018 03:08 PM by Starsearcher.)
If 64bit runs - which version for my environment? 9.0.1 seems non compatible. 8.161 is not downloadable.
01-20-2018, 03:19 PM
I think one of you is talking Windows versions and the other JAVA. Actually, you can install both 64 bit and 32 bit JAVA if you need to.
01-20-2018, 10:24 PM
You are referring to a complete image, how come the java version is not compatible?
There is a n update to 9.01 too but you certainly should be able to download 8.161 (the latest one of 8.x). Could try an off-line installer from another computer if needed.
All versions of java are free, you just have to register to be able to download outdated versions. 8.161 does not need this.
01-20-2018, 10:54 PM (This post was last modified: 01-21-2018 04:16 AM by Starsearcher.)
When the image came, it was without EWAnet. A friend has installed EWAnet. According to the message, when EPS or WIS stopped, I guess the reason is a JAVA version that is too new.
Edit:
I have installed 7.45 from which I know it runs. But the issue remained. It was the java security level. Set from middle to low and it works (with opening windows to confirm).
01-21-2018, 05:30 AM (This post was last modified: 01-21-2018 05:36 AM by autosoftware.)
if you have java security problems you can edit site list in java and it will work without problems
just add http://localhost:9000/
Mercedes Benz Wrong License for Buses in XDos2018_05 digiboy_64 6 659 07-05-2018 10:27 AM
Last Post: Crosshair
Mercedes Benz NEW! EPCnet EWAnet KG skdrasher 1,162 246,712 06-17-2018 11:45 AM
Last Post: harryzwo
  Problem installing EPC 10/2017 or 01/2018 rudi2 7 512 06-06-2018 09:44 PM
Last Post: rudi2
  MERCEDES BENZ EPC net 01.2017 Application Blocked by Java Security flterence 10 1,691 03-19-2018 05:53 AM
Last Post: camaro
Mercedes Benz 2017 Xentry/WIS/EPC/DAS/Vediamo/Monaco DTS/SDConnect Help Links Rocinante 5 63,493 03-18-2018 10:56 AM
Last Post: Diagworld
