  • 51 Votes - 3.1 Average
XENTRY 03 2012 INSTALLATION GUIDE
09-25-2012, 05:00 AM
Post: #82
RE: XENTRY 03 2012 INSTALLATION GUIDE
hello m8's
im facing another problem,
when i start installation and b4 any restart occured .. the is this error
LogLine- Error in wrinting to C:\programme\dasuinst'SETUP_ERROR.TXT
wats the solution for this ??
Life Ain't Fair Headbang
09-26-2012, 04:14 AM
Post: #83
Create a file in C:\programme\dasuninst\ called setup_error.txt and make sure its NOT read only..
 Thanks given by: ToMiBoY , flash , reddevil , Msmax
09-30-2012, 11:34 AM
Post: #84
Mercedes Benz RE: XENTRY 03 2012 INSTALLATION GUIDE
I there any way that you could post VMware image of your running system?
(06-06-2012 02:11 PM)fuchs88 Wrote:  Hello Everybody!
I am having a perfect procedure for installing Xentry 03 2012! Recently I was installing it on 2 notebooks and to be honest I was looking for some tutorials which can help people installing it. There were too many tutorials, too many opinions and too many mistakes which were making everything impossible or strange or difficult. I got angry enough and nearly have given up anyway after struggling I bring you all the solution! In points below I present the way (the easiest in my opinion) how to install Xentry!
You will need:
- Mr Zolookas NewGuide 2H
- JCRECORDINGS Tools
- -5011 Error Regfiles
- 2221-1 KEYSTATUS4 Fix
- DAS LARGEHDD Fix 533
- Das Fixes (cal872)
- COMMONLIC.DLL (NOT NECESSARY IN SOME CASES! - Needed only if APPID is different than 252! 252 is necessary to be able to install 03 2012. In other case it will cause an error and installation will not run!)
1. Do Format C: and Partition it as NTFS (not quick!)
2. Install Windows XP SP3 ENU
3. Create users OWNER and STAR and run both of them!
4. Install all necessary drivers for your computer such as Graphic Card, Sound Card, Chipset etc.
5. Delete from Add/Remove programs all components except IE!
6. Then you will need to install these programs:
- Daemon Tools
- 7zip
- Partition Manager 8
- JCRecordings Tools
7. Partition your HDD using this scheme:
(BEFORE PARTITIONING REMOVE ALL CD/DVD DRIVES INCL. DAEMON DRIVES! - YOU CAN BRING THEM BACK AFTER PARTITIONING!)
C(STAR) 15 GB
D(RECOVER) 6GB
E(WIS) RANDOM BUT MORE THAN 20 GB
F(DAS) 30 GB
8. Copy Image of Star Diagnosis 03 2012 on E(WIS).
9. Run Mr Zolookas prepare.bat and keep it OPEN!
10. When it writes to restart the cpu don't do that before you do...
a. Change in regedit BASICXP to COMPACT4
b. Add -5011 Regfiles to regedit. For that allow everybody to change folder ENUM in regedit!!
11. Now restart CPU using prepare.bat window (ENTER + ENTER!)
12. Now run setup.exe from image of 032012. The installation will force restart. Later you have to run it again! It will restart again. And during third time you start it again and it will now install Star Diagnosis (90 minutes). After that run afterinstallation.bat. From JCRecordings apply cal870 fix. Apply cal872 fix using D2 option and marked Xentry!
13. After that you will see no Xentry! To add it to your cpu you need to add in registry COMPACT2 additionally (a copy of COMPACT4 including the same subregisters!)
14. Now you have to run setup.exe from Xentry Frame.
15. After installation you will see Xentry Icon. Delete COMPACT2 from regedit!
16. SDNET has no connection! Configure your COM Port. Go to:
- Device Manager
- Choose COM PORT
- Change in Advanced COM1 to COM2. Be sure FIFO are ticked! Then OK, and change speed to 19200bps! Refresh Device Manager.
17. Run SDNET installation again. After that restart your CPU.
18. Now everything is ready to work! Use cable connection in case of D2 MUX or clone MUX! For T MUX use Wireless and configure it!
Regards!
***UPDATE***
I add some files. I don't add JCRecordings and Mr Zolookas NewGuide 2H as the files are too huge for uploading and can be easily found on internet!
10-03-2012, 03:41 AM
Post: #85
pls help me
http://mhhauto.com/Thread-03-2012-Xentry...7#pid85567
Thanks a lot !
10-12-2012, 10:13 AM
Post: #86
(08-29-2012 01:36 PM)Patrian Wrote:
(08-29-2012 01:08 PM)Msmax Wrote:  Hello Patrian,
I have the old type serial cable part D mux.
I do not doubt about the blacklist fix, but I'm running out of idea'a what to do next as I'm not very experienced with the Xentry part.
There are 2 locations where I found the cal.sli:
Bin and llist. I tried both locations. No success
I also like to say that my mux is not a chinese clone and never has given any blacklist type problems before. I also have some chinese ones and I know those sid need the fix.
So, if you have any more options for me then please shoot.
The rest of this installation works perfect and I really like to make this xentry to work.
Hi again,
In sort...
IF you NOT have any Hardware Issue (Mux or Cables) then follow those things:
1. Download the Fixed 3.2012 Bin folder for PartD Mux
2. Rename or Backup your Bin Folder
3. Un-Pack the Fixed Bin folder
4. Use the FAMOUS Xentry Blacklist Fix from Here! and read everything in this Post with HUGE ATTENTION!
5. Manage to have CORRECTLY Setup your Serial Port (COM Port = 2) and about Baudrate use 19.200!
Feedback... Sweating
Finally FYI, your Mux be sure is 100% Blacklist! Nod I can put and 1x Bet if you like... Kolo
Ecxept if you using any "Hacking" Hardware Tools and you changing Time-To-Time (and when needing) the S/N... 533
Best Regards! Cheer2
AP
Hello Patrian,
I have got my DAS 07/2012 to work only with your "FULL BIN 3.2012 FIXED FOLDER".
Thank you very much!
Unfortunately is my DAS no more 07/2012 but nothing else helped in my case.
Could you make same fixed folder for 07/2012?
Best Regards!
Fing32Fing32Fing32
10-13-2012, 04:38 AM
Post: #87
Hello Everybody das xentry 03/2012 multiplexer original 100% work bat china multiplexer Error
870 ??????????????????????????//
10-21-2012, 11:18 AM
Post: #88
Hi !
I already installed Xentry 03.2012 following the guide on first post and installation was successful and without problems.
try to connect with car C220 Cdi 2002 and got this error:[attachment=11803]
have tried with full bin folder 03.2012 but got another error:[attachment=11804]
can anyone help me ?
10-21-2012, 07:13 PM
Post: #89
Help !
Regular update period for this system has ended:20071231/20100930(YYYYMMDD)
This update is not granted on this system.
Thanks.
10-21-2012, 09:17 PM
Post: #90
(10-21-2012 07:13 PM)art4620 Wrote:  Help !
Thanks.
You have to start with a clean machine and fresh install of XP SP3.
Then the guide says to set your computer date to 1 month after the release date of your installation DVD. For 032012 set to 042012.
VW VAS-PC v.19.01.01 Install Guide getaibose 5 11,773 Today 07:51 AM
Last Post: down_load
  ODIS 4.1.4 installation error choltong 5 234 09-14-2017 10:16 AM
Last Post: panfuty
  Atris Technik 2016 Step by Step installation manual + extras valentino_val 6 3,157 09-10-2017 01:54 PM
Last Post: titan80
  DTC removal guide needed olks 0 162 09-08-2017 04:17 AM
Last Post: olks
Mercedes Benz Mercedes EPC/WIS/EWAnet Video Installation Guide 2014 Yudi 90 41,653 08-23-2017 11:04 PM
Last Post: david_dung
Peugeot Peugeot Service Box Installation Instructions. webmaster 86 84,278 08-22-2017 09:19 AM
Last Post: Walter01
  Win XP installation Bartekj 3 260 08-20-2017 08:14 AM
Last Post: jetdede
  UPA USB ECU Programmer V1.3.0.14 Installation Guide ! pattersonlyy 0 305 08-14-2017 01:01 AM
Last Post: pattersonlyy
AA Bosch-logo Bosch ESI Installation guide webmaster 96 106,288 08-10-2017 03:26 AM
Last Post: Bartekj
Mercedes Benz Original Mercedes EPC/WIS/ASRA User’s Installation Guide webmaster 1,113 478,468 08-01-2017 08:59 AM
Last Post: ToMiBoY
