  • 108 Votes - 3.18 Average
12-04-2015, 12:20 PM (This post was last modified: 12-04-2015 12:36 PM by morepower.)
Post: #379
For all of you having trouble with the update (device is silent, etc), make sure you follow these steps:
1) program Atmega correctly and at the end fuse the bits correctly (false=check, true=unchecked)
(atmegas don't autodestroy with software so don't buy a new one)
2) Program FTDI with:
PID 7101
500 miliAmps
02 serial number prefix
ELDB manufacturer
XPROG-box description
3) install correct drivers for this PID 7101 or take a generic FTDI driver and add this PID to the .inf files
4) go to driver manager and on XPROG set the COM port to 1. ALSO SET LATENCY TO 1ms.
5) disconnect XPROG, reconnect, start software and VOILA!
You don't need to Thank or Rep me Smile
I only hope it helps
----UPDATE, ept and driver included Pc 049
DEVICE MANAGER ---> XPROG ---> advanced ---->LATENCY 1ms !!!!!!!!!
Attached File(s)
XprogBOX_pid7101.rar
File Type: .rar
Downloaded: 218 times
USB_Driver_XPROG7101.rar
File Type: .rar
Downloaded: 247 times
 Thanks given by: michalez , Cesarec , charles.soori , alisalama2004 , max72 , zalimhan74 , alex_ng , liviu2004
12-05-2015, 12:19 AM
Post: #380
I have the same problem SILENT means com port not the same Smile.
Manager see what com prot is and put it the same from xprog option.
12-09-2015, 04:14 AM
Post: #381
Man Im new around here and I have got to say, all your contributions are legendary. Thanks Luis!
12-09-2015, 05:40 PM
Post: #382
(12-05-2015 12:19 AM)k1champion Wrote:  I have the same problem SILENT means com port not the same Smile.
Sorry i didn't understand you totally, What do you mean exactly?
12-21-2015, 01:13 AM
Post: #383
Works great, thank you very much! Good Job, Louis!
01-07-2016, 07:04 AM (This post was last modified: 01-07-2016 08:39 AM by steves.)
Post: #384
Where's best place to buy xprog from?
01-14-2016, 10:03 AM (This post was last modified: 01-14-2016 10:07 AM by crashndash.)
Post: #385
Ignore that its 5.55 I need
01-19-2016, 02:55 AM (This post was last modified: 01-19-2016 03:26 AM by samedi.)
Post: #386
(09-01-2015 09:11 AM)BoNzO Wrote:  yes but your code and data is the same yes after you lock fuse?
Is any one hawe isue with UPA 1.3 when traying to update ATmega64 when i press read in UAPA on botom hawe error
OI Error
Reading:1 errors Fund device ATmega 64 range :0-FF
MOSI 3.11 V Bad
01-19-2016, 03:57 AM
Post: #387
(01-03-2015 01:37 PM)krammer2262000 Wrote:  Hello , can any of you guys confirm that XPROG is capable of erasing eeprom M35080 ???
I am trying to erase the Incremental Registers to one eeprom m35080 , but without success. I just need to know if Xprog can do this job , or my unit is defective
P.S. I can read the eeprom without any problem , I can write it also as long as the value is higher . I just cant erase the incremental registers.
Thanks.
YU CAN DO TIHAT WITH R270 PROGRAMTOR
  XPROG 5,72 from china, i need activator for this software please Fan_Thomas 8 613 11-18-2017 12:14 AM
Last Post: Fan_Thomas
  Xprog strixas 4 453 11-17-2017 02:56 AM
Last Post: vwman
  Xprog 5.7.0 Controller not responding Zix1 3 352 11-03-2017 06:44 AM
Last Post: ermuraky1
  Xprog- Unknown command.Software error bawareca 8 4,995 11-02-2017 11:00 PM
Last Post: piotrekwoj1
  XPROG-M 4.5 BMW CAS3 Xeon1 5 290 10-27-2017 01:14 PM
Last Post: laz79
  Xprog 5.5.5 Flash Atmega64 ; Bin. HEX free!! timorlank 40 21,586 10-26-2017 12:52 PM
Last Post: farah676
  XPROG 5.5.5 to 5.7.6, software and firmware update minimex 49 13,930 10-23-2017 04:02 AM
Last Post: cardos84
  Xprog M V5.70 getdanny 9 1,321 10-14-2017 01:56 AM
Last Post: getdanny
  Question about xprog Atmega64 EGYAUTO 4 232 10-01-2017 02:45 PM
Last Post: m3touk_85
  xprog 5.70 eprom 93lc46 farciroberto1991 2 362 09-23-2017 03:10 PM
Last Post: farciroberto1991
Krisrw, 2 Guest(s)
