  • 91 Votes - 3.22 Average
01-19-2016, 02:55 AM (This post was last modified: 01-19-2016 03:26 AM by samedi.)
Post: #388
(09-01-2015 09:11 AM)BoNzO Wrote:  yes but your code and data is the same yes after you lock fuse?
Is any one hawe isue with UPA 1.3 when traying to update ATmega64 when i press read in UAPA on botom hawe error
OI Error
Reading:1 errors Fund device ATmega 64 range :0-FF
MOSI 3.11 V Bad
01-19-2016, 03:57 AM
Post: #389
(01-03-2015 01:37 PM)krammer2262000 Wrote:  Hello , can any of you guys confirm that XPROG is capable of erasing eeprom M35080 ???
I am trying to erase the Incremental Registers to one eeprom m35080 , but without success. I just need to know if Xprog can do this job , or my unit is defective
P.S. I can read the eeprom without any problem , I can write it also as long as the value is higher . I just cant erase the incremental registers.
Thanks.
YU CAN DO TIHAT WITH R270 PROGRAMTOR
01-19-2016, 08:02 AM (This post was last modified: 01-19-2016 08:59 AM by samedi.)
Post: #390
Need help
All done update xprog werified xproog all green but now when trying to reed chip in xproog i got unknown software cmendd error
is any one know issue
(12-05-2014 11:57 AM)cardiagpt Wrote:  hi
problem solved
i try new xprog and works
thanks to all
Hi bro
I hawe same problem with that error
Wich software you use can you giwe me link and explane to me how solwe this error
THANKS
01-22-2016, 01:12 PM
Post: #391
Hi; many thanks for upgrade. All is good. But there is a great problem...Unknown command error software...Is there someone here has a solution for that please?
Regards.
01-23-2016, 01:48 PM
Post: #392
Hi again; finally all is ok...
01-28-2016, 02:23 PM
Post: #393
Can anyone tell me if this has to be:at hardware registration ID look this ---------------- ,i dont know its ok.tkx
02-03-2016, 05:18 AM
Post: #394
Hello
I have a problem.
I do update 5.5.1, and run the program and everything is OK.
The problem arises when I want to read / write a memory, one time out of ten times I can do this, the rest is silent device.
What am I doing wrong?
In the previous version 5.0 worked flawlessly.
If I helped, click [Image: postbit_reputation.gif] and [Image: postbit_thx.gif]
02-03-2016, 02:13 PM
Post: #395
(02-03-2016 05:18 AM)rch11 Wrote:  Hello
I have a problem.
Are you sure latency is set to 1 in the USB xprog settings?
02-03-2016, 09:39 PM
Post: #396
I have a problem.
What and how to save XprogBOX_pid7101.ept?
  Xprog 5.5.5 Flash Atmega64 ; Bin. HEX free!! timorlank 34 11,390 Yesterday 07:12 PM
Last Post: chong5195
  XPROG 5.7.4 Software and Firmware Update pv_sas 16 5,403 01-10-2017 11:47 PM
Last Post: arimmati
  Xprog not working obd.tech 38 14,619 01-08-2017 07:18 AM
Last Post: beameup
  Where to buy good xprog? laz79 6 436 12-16-2016 07:15 AM
Last Post: amgadtoony
AA+MHH Xprog vs Orange5 vs Smok vs UltraProg ervis 23 9,020 12-09-2016 03:36 PM
Last Post: Heleje
  Problem with xprog chaoui05 9 528 11-17-2016 11:19 PM
Last Post: chaoui05
  xprog fimware 5.5.5 ATmega64 ahmedrezk 32 12,359 11-05-2016 05:26 PM
Last Post: monini64
  XProg BDM cable connectors source nogger 4 585 09-20-2016 03:02 AM
Last Post: autodigitec
  buying xprog clone Jastr 2 326 08-30-2016 01:38 AM
Last Post: Raints
  Xprog - Carprog - UPA-USB febeks 21 3,653 08-29-2016 08:00 PM
Last Post: thcspb
