  • 95 Votes - 3.2 Average
03-09-2016, 12:40 AM
Post: #406
This solution help me to use XProg-M v5.51 from LuisAndre with Adobe Reader XI in Windows XP without error messagebox after start this app or auto-close this app after start, also.
Short words.. You must do update of Reader XI to version 11.0.14. And because Adobe ended support of Reader XI for Windows XP by update 11.0.8, you must do it manually.
Please download this update file from Adobe site and install it. After update to version 11.0.14 you can also download and install update 11.0.15 and probably newer in future.
Link is in attached .txt file below.
Regards,
MT
Attached File(s)
XProg-M v5.51 [Adobe Reader update links].txt
File Type: .txt
Downloaded: 195 times
 Thanks given by: bouizanne , alex_ng
03-21-2016, 09:11 AM
Post: #407
Thank you LUIS ANDRE!!! Tested on bmw e 46 dash (bosch) read, erase and write on 35080!
Best regards Smile
03-25-2016, 11:35 AM
Post: #408
Does anyone has an issue with 5.5.1, like you read successfully eerpom or MCU, then you want to read/wrige again, and software always hangs on Checking Device..?
Before it was working fine, this problem just started recently. Tried on 2 different PC - same.
04-02-2016, 07:30 PM (This post was last modified: 04-02-2016 07:30 PM by gbyleveldt.)
Post: #409
I also had this issue recently. What worked for me was to block XprogDesktop.exe in my Firewall and it's been working perfect ever since.
I think what went wrong for me is that I clicked 'Check Authorizations Updates' Under the Xprog hardware info menu. Yes, it was stupid Smile
Another interesting fact: I bought another clone 5.50 and didn't even need to flash the Atmega. All I did was run the XProg update as per the initial instructions in the .rar file. Once the XProg was updated all authorizations were available.
I now have two working ones based on Luis' excellent work.
 Thanks given by: jcgabbi
04-06-2016, 06:08 AM
Post: #410
Hello, I have a problem, Xprog 5.51 crashes when hooked is the internet, does one read and the end, when the Internet is off operating normally.
04-08-2016, 03:11 AM
Post: #411
(03-26-2015 07:46 AM)IheartCars Wrote:
(03-26-2015 04:39 AM)Slayder Wrote:
(03-25-2015 07:03 PM)IheartCars Wrote:
(03-25-2015 03:11 PM)Slayder Wrote:  Updated via USBASP and AVRDude to latest, got "Device is Silent". Ordered new Atmega64a from Digikey and replaced. It got detected in AVRDude and reprogramed, bits set 2F CA FF FC. Plugged in gets detected in Device Manager, ran 5.51 and when click on Upgrade I get again "Device is Silent". Same thing on two different computers. Any help please
Did you change the environment within X-Prog to the usb port found in device manager? It's under Option==>Enviromnet
Br
Yes, it gets auto detected as soon I plug the Xprog in.
Use extreme burner with the file attached. Photo are proof that it worked. If you're still having issues with the attached file, than re-check your atmega64a solder connection for solder bridges.
BR
Many thanks to LuisAndre & iheartCars for their work/posts on this and it has allowed me to get my china clone back up & running (sort of !). I used ExtremeBurner but was unable to load the dump in post 1 ( it complained of corrupted hex file even though i downloaded again,i think it maybe needs to be converted to hex for ExtremeBurner. The dump from iheartCars would load & after setting the fuse & lock bits i burnt the Atmega. Using luisAndre's software for 5.5.1 i started the program & it did update ok. I was able to read a 9s12e secured chip fine (still get occasional verify errors though only 2 or not 20 or 30 like before !). One annoying problem though, it locks up after just one operation, a read or a write or erase, i have to quit the program & reload before every operation, anyone got any ideas why this is happening ?
Many thanks
Nogger
 Thanks given by: Droidkiller
04-08-2016, 03:41 AM
Post: #412
See my post 409.
 Thanks given by: nogger
04-08-2016, 11:24 AM
Post: #413
(04-08-2016 03:41 AM)gbyleveldt Wrote:  See my post 409.
How to block xprog in firewall??
If it is useful...then use Thanks button and Reputation!!
Thankyou
04-08-2016, 11:46 AM
Post: #414
Hi to all members.
First of all thank's a lot Mr.Luis Andre,his work is great.I tried several eeproms with updated Xprog M.In environment options I cannot activate erase and verify/blank check mode,and tools also inactive.
Any idea?Itwasntme
Thanks for advance
VW Xprog v5.7 clone hasslavane 6 811 02-17-2017 10:44 AM
Last Post: collmen
VW Xprog v5.55 with dongle soft need essamistar 3 136 02-16-2017 11:23 PM
Last Post: Kim1980
  XPROG 5.5.5 to 5.7.6, software and firmware update minimex 29 3,008 02-15-2017 11:55 PM
Last Post: dadaesjoel
Mercedes Benz Xprog-M damaged... Please help !! Jan1980 19 10,252 02-13-2017 03:08 AM
Last Post: kilog
AA Bosch-logo About Xprog connections interfete-obd 8 3,367 02-04-2017 07:54 AM
Last Post: gstardiag
  Xprog 5.5.5 Flash Atmega64 ; Bin. HEX free!! timorlank 35 12,681 02-03-2017 02:11 AM
Last Post: Indigo
  XPROG 5.7.4 Software and Firmware Update pv_sas 16 6,244 01-10-2017 11:47 PM
Last Post: arimmati
  Xprog not working obd.tech 38 14,965 01-08-2017 07:18 AM
Last Post: beameup
  Where to buy good xprog? laz79 6 500 12-16-2016 07:15 AM
Last Post: amgadtoony
AA+MHH Xprog vs Orange5 vs Smok vs UltraProg ervis 23 9,364 12-09-2016 03:36 PM
Last Post: Heleje
