  • 106 Votes - 3.19 Average
04-24-2016, 09:24 AM (This post was last modified: 04-24-2016 09:31 AM by narkeleptk.)
Post: #424
(04-21-2016 08:25 AM)Madrid-ECU Wrote:  Could anyone send me the xprog 5.51 SW by LuisAndre?
Dont work the links.
I put up for people if anyone still needs it.
thnx/rep is nice if I've helped you.
Attached File(s)
xprog5.51(by LA).txt
File Type: .txt
Downloaded: 1510 times
 Thanks given by: dari2dari , VR-6 , butonu , hayabusa45 , hoangtu , Geza , meysen , bouizanne , sv2hqx , Robbert , prof.memet , seva , daxxer , fluorescent , tkinyan , Patkan48 , evaldaz , hbalazs , pinout , dinho , pricardof , canlock , 53R910 , zalimhan74 , danicosta91 , ati2 , asimor , charles.soori , plasticman1971 , bmwfan76 , Rolik77 , Mecanodiag75 , alex_ng , ACDC , shortscoff , crez , illestibor , badro diag , ciekawy , sweetsam , szenti71 , Jaycee230 , autobirotula , djkrugger , Faiq , Salim , dunt , bagelhs , tintin2005 , doorman007 , madbg1 , gateone , mercomoh , jguerrasolana , alatech , leona-lvov , Blackstone , kokibom , nerp , isak2009 , Darke , valentino_val , Styvo254 , rUxx , Miragui , CheMax , mcb58 , ph0en1x , rrador , davidcie , fly_garage , antonypaul , dan93 , vertyk , JarsaR , stefy_hgs
05-05-2016, 08:57 AM
Post: #425
I update my x-prog 5.51.everything was ok.but when i use this write (unkown command.software error) please help.
05-05-2016, 11:37 AM
Post: #426
(05-05-2016 08:57 AM)xalik Wrote:  I update my x-prog 5.51.everything was ok.but when i use this write (unkown command.software error) please help.
describe your steps.
05-12-2016, 08:32 AM
Post: #427
hi i update my xprog-m 5.0 to this version 5.51,and now i can read eeproms for testing but i can't read it,the staut monitor is stay planted on check device!?? i disconnect the programmer from usb and use manager task to kill the whole process.
i change another programmer and all go without problem read & write...any help please Sweating
05-12-2016, 06:32 PM
Post: #428
Hello
Check my Post 416,maybe helps
 Thanks given by: DDJAM
05-13-2016, 01:38 AM
Post: #429
(05-12-2016 06:32 PM)Droidkiller Wrote:  Hello
hi,i do like you said :i make exception of "xprogdesktop.exe" in my firewall,i reinstall adobe reader v10,and i turn off my internet connction.Now it work goodCheer2
thank you bro for the ticks,regards
05-24-2016, 10:29 PM
Post: #430
hi to all
i face the following issue
i can read or write only once any mcu
second time stuck on ''check device'' and only green led is on and i cant even close program
can close only from task manager
after restart working again but one time
win7 32 bit
couple weeks ago was working
dont know if this was after an update
05-28-2016, 01:46 AM
Post: #431
(05-24-2016 10:29 PM)sv2hqx Wrote:  hi to all
win7 32 bit
Hello sv2hqx
i have the same problem with my xprog 5.51.
Worked many month with no problem but now i can read or program only once. I need to close and reopen each time otherwise the software freeze.
I try to uninstall, resintall.... always the same problem.
I try my xprog with another computer, works fine......
05-28-2016, 02:45 AM
Post: #432
Hello sv2hqx
[/quote]
solved
replace xprog.exe from zip and will be fine
at least worked for me
 Thanks given by: plasticman1971
  xprog 5.5.5 error xprogdesktop.dll drugowaz 4 1,975 09-17-2017 06:24 AM
Last Post: Botosjeti
  Xprog M V5.70 getdanny 4 551 09-16-2017 07:46 AM
Last Post: acmotor
  Xprog Clone 5.55 Update Zix1 0 129 09-16-2017 01:50 AM
Last Post: Zix1
  Xprog 5.5.5 Flash Atmega64 ; Bin. HEX free!! timorlank 39 19,476 09-12-2017 10:41 AM
Last Post: Baran79
  Using XProg BDM adapter for Micronas CDC32xx nogger 5 322 09-08-2017 03:59 PM
Last Post: narkeleptk
  Xprog 5.51 upgrade to 5.60 cardiagcom 0 259 08-29-2017 09:25 AM
Last Post: cardiagcom
  XPROG vs Universal Eeprom Programmer Levon 11 4,029 08-28-2017 07:16 AM
Last Post: @[email protected]
  Xprog addons diablotic 4 357 08-24-2017 03:32 PM
  R270 ATMega Dumps!Willing To PAY koska147 2 209 08-24-2017 06:35 AM
Last Post: simon1414
  XPROG 5.5.5 to 5.7.6, software and firmware update minimex 48 11,836 08-07-2017 01:08 PM
Last Post: kidloco
