If your a registered member in MHH and your not able to login or recover your account, Kindly contact webmaster@mhhauto.com
  • 95 Votes - 3.2 Average
05-28-2016, 01:46 AM
Post: #433
(05-24-2016 10:29 PM)sv2hqx Wrote:  hi to all
i face the following issue
i can read or write only once any mcu
second time stuck on ''check device'' and only green led is on and i cant even close program
can close only from task manager
after restart working again but one time
win7 32 bit
couple weeks ago was working
dont know if this was after an update
Hello sv2hqx
i have the same problem with my xprog 5.51.
Worked many month with no problem but now i can read or program only once. I need to close and reopen each time otherwise the software freeze.
I try to uninstall, resintall.... always the same problem.
I try my xprog with another computer, works fine......
05-28-2016, 02:45 AM
Post: #434
Hello sv2hqx
[/quote]
solved
replace xprog.exe from zip and will be fine
at least worked for me
 Thanks given by: plasticman1971
06-19-2016, 05:16 AM (This post was last modified: 06-23-2016 04:54 PM by narkeleptk.)
Post: #435
(06-17-2016 01:47 AM)Perryking Wrote:  I tried to download this, but files was deleted. Can someone upload again?
Thanks!
The one i put up is still working
http://mhhauto.com/Thread-XProg-5-5-1-so...#pid684040
06-21-2016, 12:01 PM
Post: #436
(04-21-2015 05:39 PM)narkeleptk Wrote:  Success!
I used a cheap USB-ASP along with khazama and the hex files provided by marmaro (page 11 - post #84).
After you have your connections all done.
Step 1 - Configure Khazama by going to >Commands>>Programming Options and set like in picture.
Step 2 - Set Fuse and Lock bits like in my picture but do not write them. Just set them and then close the window by the X
Step 3 - Load the HEX files marmaro converted. Atemga~1 to "F" (flash) and EEP to "E" (eeprom). The F & E button on top left. Then click AUTO PROGRAM.
Also if you get the error I was getting just ignore it.
Once done remove your connections. Hook Xprog to PC (COM1). Run LA's 5.51 software. Verify in options your software is also set on com1. Then hit the UPDATE button.
Settings work for 5.55 update!
 Thanks given by: narkeleptk
06-21-2016, 11:46 PM
Post: #437
Hi all. I want download LuisAnde's file on Mega but Mega request me -
"The file you are trying to download is no longer available.
The associated user account has been terminated due to multiple violations of our Terms of Servicе"
Somebody save that file? Please, download here if you can.
06-22-2016, 10:13 PM
Post: #438
Having this fault after loader closes, and later that screen won't disapear
Attached File(s) Thumbnail(s)
06-23-2016, 04:55 PM
Post: #439
(06-21-2016 11:46 PM)serg264 Wrote:  Hi all. I want download LuisAnde's file on Mega but Mega request me -
 Thanks given by: serg264
07-18-2016, 10:33 AM
Post: #440
Thanks LuisAndre Smile thanks great
But when i start program i can read example mcu motorola 1 time, but if i try second time is hanging on checking.
Anyone advice about this error?
07-18-2016, 12:38 PM
Post: #441
I have the same issue dont know how to solve it...
Known as Dziwak77 or Tomski Call
41
VW Xprog v5.7 clone hasslavane 6 772 02-17-2017 10:44 AM
Last Post: collmen
VW Xprog v5.55 with dongle soft need essamistar 3 129 02-16-2017 11:23 PM
Last Post: Kim1980
  XPROG 5.5.5 to 5.7.6, software and firmware update minimex 29 2,840 02-15-2017 11:55 PM
Last Post: dadaesjoel
Mercedes Benz Xprog-M damaged... Please help !! Jan1980 19 10,223 02-13-2017 03:08 AM
Last Post: kilog
AA Bosch-logo About Xprog connections interfete-obd 8 3,357 02-04-2017 07:54 AM
Last Post: gstardiag
  Xprog 5.5.5 Flash Atmega64 ; Bin. HEX free!! timorlank 35 12,627 02-03-2017 02:11 AM
Last Post: Indigo
  XPROG 5.7.4 Software and Firmware Update pv_sas 16 6,192 01-10-2017 11:47 PM
Last Post: arimmati
  Xprog not working obd.tech 38 14,941 01-08-2017 07:18 AM
Last Post: beameup
  Where to buy good xprog? laz79 6 500 12-16-2016 07:15 AM
Last Post: amgadtoony
AA+MHH Xprog vs Orange5 vs Smok vs UltraProg ervis 23 9,334 12-09-2016 03:36 PM
Last Post: Heleje
