  • 106 Votes - 3.19 Average
08-28-2016, 12:52 AM
Post: #442
Link dont work. Does anyone send me it?
EGR/DPF/Swirl/DTC OFF
Tuning File Service - Original File Service - Map Packs
Official Tools and Licensed WinOLS
08-28-2016, 01:36 AM
Post: #443
(08-28-2016 12:52 AM)gianluca84 Wrote:  Link dont work. Does anyone send me it?
plz put some effort in it and don't assume all is dead, use the search button for a change or do you want everything handed out to you on a silver platter... Rain
http://mhhauto.com/Thread-XProg-5-5-1-so...#pid684040
They will have to pry the mouse from my cold dead hand.
Don't PM me for SW keys, Licences, radio codes or similar, you will not get any answer...
 Thanks given by: daxxer , bmwfan76 , narkeleptk , activeau , liviu2004
08-31-2016, 01:27 PM
Post: #444
(12-17-2014 10:54 AM)PhilipM Wrote:  This works fine with xprog 5.0, no dongles needed for me.
Tools- cheapest is USBASP from ebay, you'll probably have enough change in your pocket for one right now.
You need to install acrobat reader 10, it will complain, and it uses this for help pictures.
I used extreme burner (free sw) to work with USBASP, you can use avrdude if you like command lines!
http://extremeelectronics.co.in/avr-tuto...ogrammers/
You can try and read your original ATmega, I saved a copy of my xprog50 ATmega and EEP dump.
Connect with the picture supplied in the link in post 1
select ATmega64A in extreme burner.
click erase, this should work OK, if not check your connection.
read the file again to check, your flash and eep windows should be clear.
Forget about the LOAD button, this is a horrible feature, select eep as the active window and go to OPEN, and select the xprogluis.eep file, and check it has loaded into the eep window, and not the flash window.
click the flash window/tab, open the xprogluis.hex file and make sure it loads into the flash window.
Change between the tabs to make sure the flash and eep files have different contents, extreme burner was not good at this so check!
Select write from the top bar and write flash
Select write from the top bar and write eep
go to the fuse bits tab
low fuse should say 2F
high fuse should say CA
extended should say FF
Lock fuse should say FC
Originally the fuse bits were correct already, but the lock byte was FF.
If you need to change a fuse byte, you will need to click the write checkbox too before you click write (calibration can be left as it is)
When I first did this, I had no auth. for the secured CAS uP's, "device not registered"
When I repeated this, I saw the check box for write lock byte, tick the box and write again, and now it shows as registered and working for everything.
My link is for my original xprog 5.0 and Luis' xprog 5.5.1 hex and eep files for Extreme burner in .hex format (extreme burner does not work with binary)
Once you have the flash, eep and fuse/lock bits set up, start the supplied Xprog exe, check in environment you have it to the correct COM port, and click update, and it will update the firmware.
Click update after to see the authorisations.
If you don't have the auth, try again with the ATmega64 and Eep programming. If you can read out the file, the lock bit isn't set!
Thank you man, very helpful. I managed to unbrick my xprog AND update to boot!
Now I have two working Xprog!
09-03-2016, 03:06 AM
Post: #445
Hello .
I'm a new and i want your help. A friend had give me a clone xprogm 5.48 hardware without software. I'm have download this sofware I open this and my hardware says it needs firmware update Can i do it firmware update or that will kill my hardware.????
Thanks a lot
09-06-2016, 09:29 AM
Post: #446
(09-03-2016 03:06 AM)bmwfan76 Wrote:  Hello .
Thanks a lot
You will find everything you need to get it working by reading through this topic...
 Thanks given by: bmwfan76
10-19-2016, 09:50 AM
Post: #447
Hi ppl,
after reflashing xprog with another xprog, with files from here, under help/hardware info i have "device is silent" error. I did it with Luis Andre's sw from here too.
I reflashed atmega several times, but still the same...
Any advice?
10-19-2016, 07:18 PM
Post: #448
Hi,in environment settings choose the correct usb port of your xprog box
10-28-2016, 05:46 AM
Post: #449
(10-19-2016 09:50 AM)braco Wrote:  Hi ppl,
Any advice?
I have one xprog box doing this, its the usb socket on the board. I have power so it recognises it on com3, but its the connections on usb socket for me so look there.
11-09-2016, 12:23 PM
Post: #450
hi all after update china clone with avr910 v5.3 to v5.51 device is silent.Why all fuses end another is the same . pls help
  xprog 5.5.5 error xprogdesktop.dll drugowaz 4 1,975 09-17-2017 06:24 AM
Last Post: Botosjeti
  Xprog M V5.70 getdanny 4 552 09-16-2017 07:46 AM
Last Post: acmotor
  Xprog Clone 5.55 Update Zix1 0 129 09-16-2017 01:50 AM
Last Post: Zix1
  Xprog 5.5.5 Flash Atmega64 ; Bin. HEX free!! timorlank 39 19,481 09-12-2017 10:41 AM
Last Post: Baran79
  Using XProg BDM adapter for Micronas CDC32xx nogger 5 323 09-08-2017 03:59 PM
Last Post: narkeleptk
  Xprog 5.51 upgrade to 5.60 cardiagcom 0 259 08-29-2017 09:25 AM
Last Post: cardiagcom
  XPROG vs Universal Eeprom Programmer Levon 11 4,029 08-28-2017 07:16 AM
Last Post: @[email protected]
  Xprog addons diablotic 4 357 08-24-2017 03:32 PM
  R270 ATMega Dumps!Willing To PAY koska147 2 209 08-24-2017 06:35 AM
Last Post: simon1414
  XPROG 5.5.5 to 5.7.6, software and firmware update minimex 48 11,836 08-07-2017 01:08 PM
Last Post: kidloco
aboaljeez, 3 Guest(s)
