  • 105 Votes - 3.21 Average
11-09-2016, 12:23 PM
Post: #451
hi all after update china clone with avr910 v5.3 to v5.51 device is silent.Why all fuses end another is the same . pls help
11-16-2016, 08:38 AM
Post: #452
i did all steps and update firmware but when start reading any device gave an error (error software ) searched again for this error i found it here in the same thread i followed the instruction for changing the lock bits but now its not working even the pc not recognize it and by the programmer its cant reprogram its given me just 000 for flash and memory and all lock bits and fuse bits ALL CHECKED AND CANT WRITE NEW CONFIGURATION IS THERE ANY SOLUTION FOR THIS.THANK YOU
REGARDS SAM Fing32
11-19-2016, 09:29 PM
Post: #453
Hi. Normally i am working with my xprog original. I have xprog clone, too. Now, i want to sell it to a mate in nice working condition of course. Clone was Version 5.0. Now, i wrote atmega with the files and it works perfectly. But only one time ! It reads and writes perfectly. But just first action in program works. If i want to read second time for example, green LED on xprog is on, but no action. I have to end the xprog program in task manager and unplug xprog. If i start again, i can write or read, but always just one time !! What can i do ? THX !!!
 Thanks given by: Jaycee230
11-19-2016, 10:05 PM
Post: #454
Hi
First try reinstall Adobe and turn off internet before starting Xprog software.
It was useful for me.
Press thanks and rep if my post helped
Regards
 Thanks given by: Jan1980 , Jaycee230 , onlyzidic
11-26-2016, 08:01 AM (This post was last modified: 11-28-2016 02:43 AM by Jaycee230.)
Post: #455
(11-19-2016 09:29 PM)Jan1980 Wrote:  Hi. Normally i am working with my xprog original. I have xprog clone, too. Now, i want to sell it to a mate in nice working condition of course. Clone was Version 5.0. Now, i wrote atmega with the files and it works perfectly. But only one time ! It reads and writes perfectly. But just first action in program works. If i want to read second time for example, green LED on xprog is on, but no action. I have to end the xprog program in task manager and unplug xprog. If i start again, i can write or read, but always just one time !! What can i do ? THX !!!
I'm getting EXACTLY same issue! I can downgrade back to v5 without issue, but every time Install v5.5.1 everything goes to plan, program eep & flash in atmega set fuse & lockbits, I've installed adobe v10 - update software - all fine, I read first device without fail but if I try to read a second time or another device it just jams with green light on?, if I terminate software & restart it does the same thing everytime??? can anybody help us here???533
**********************SOLVED******************
Works with internet off! (Start program with internet off & then can switch internet back on whilst running - no probs)
although I have tried blocking with defender firewall & makes no difference, I'm running XP - anybody know how to get over this minor hurdle??
Please hit the reps & thanks buttons if this post was helpful!!!!
11-29-2016, 11:32 PM (This post was last modified: 11-29-2016 11:33 PM by DDJAM.)
Post: #456
hi, i have update my xprog 5.0 sucessefully to this version 5.51, & now i ask if i can update to 5.55 or i need some special procedure....Sadsmile
regards
11-30-2016, 01:21 AM
Post: #457
(11-29-2016 11:32 PM)DDJAM Wrote:  hi, i have update my xprog 5.0 sucessefully to this version 5.51, & now i ask if i can update to 5.55 or i need some special procedure....Sadsmile
regards
Stick with this 5.5.1 its the most stable by far at the moment, thanks to the main man luis andre
 Thanks given by: DDJAM , narkeleptk , dinho
12-28-2016, 02:22 AM
Post: #458
thank you very much. it worked
12-29-2016, 12:59 AM
Post: #459
Link not work!!! Sad
  why xprog 5.55 need firmewre update after reflash yanko 3 215 Today 03:31 AM
Last Post: marmaro
Audi MPC5607b - reading with XProg 5.55 - which diagram is correct Technix 0 116 07-15-2017 11:22 AM
Last Post: Technix
  XPROG 5.5.5 to 5.7.6, software and firmware update minimex 46 9,311 07-11-2017 11:11 AM
Last Post: CHAVCAR
  Xprog 5.5.5 Flash Atmega64 ; Bin. HEX free!! timorlank 38 17,432 06-27-2017 04:08 PM
Last Post: Nabil77
  X PROG 5.51 ATMEGA 64 DUMP AND SOFTWARE NEED shervin 4 423 06-21-2017 06:18 AM
Last Post: magna413
  Carprog vs upa usb vs xprog m ionutdanica 7 730 06-15-2017 09:28 PM
Last Post: Kim1980
  why xprog 5.55 need firmewre update after reflash yanko 1 142 06-15-2017 11:38 AM
Last Post: Stinger88
  xprog 5.55 clone software please ashu01 0 193 06-05-2017 07:42 PM
Last Post: ashu01
  problem xprog box argen.dll bahlawi 1 139 05-22-2017 09:35 AM
Last Post: narkeleptk
  xprog box error brazaru 3 833 04-24-2017 08:17 PM
Last Post: margjelin
