  • 1 Votes - 3 Average
a8 d3 cluster reset component protection problem
Array
08-20-2017, 03:05 AM
Hello
I have a problem removing component protection in audi a8 d3 2004r
I tried deleting it from AVDI org and fvdi china but unfortunately it does not give any results all the time i am displaying error i like the image below i may already have someone like this problem and found solution>
Attached File(s) Thumbnail(s)
08-20-2017, 03:22 AM
RE: a8 d3 cluster reset component protection problem
try to reflash with odis.
08-20-2017, 06:25 AM
you are using the dump from the gateway from the car where the dashboard came from?
08-20-2017, 09:45 AM
No avdi does not need a throw from the gate should do everything after obd.
counter comes from the web auction i do not have an original counter
08-20-2017, 09:52 AM
use v18 version.
08-20-2017, 09:54 AM
V18 I checked not working
09-01-2017, 10:29 AM
The fight continues.
I have already a counter with the same number but still avdi shows the error as well
question whether i must have kessy or geteway with this auto where does the counter come from?
  VALEO J34P 21586048-9A HW9651696680 need component ID electronico_nc 0 51 09-14-2017 09:55 PM
Last Post: electronico_nc
  Discovery Media PRO Component Protection magna413 21 6,904 09-02-2017 04:15 AM
Last Post: magna413
  Mercedes KEY surface mount Infrared electronic component szczęśliwy WEP 0 114 08-31-2017 05:18 PM
Last Post: szczęśliwy WEP
Audi Component protection remove, Audi A6 c7 sachek 3 270 08-24-2017 05:45 AM
Last Post: absetup
  BMW E66 problem reset brake pad light shmuk 10 406 08-20-2017 09:28 AM
Last Post: makssenior
  Passat b7 cluster (odometer) Problem ziomal4340 1 191 08-17-2017 11:00 AM
Last Post: telucu17
  Component Protection 8T0920931T (audi a5 dash) autoexpertdiag 7 300 08-05-2017 03:43 AM
Last Post: autoexpertdiag
  Component protection off Audi q7 [email protected] 2 246 07-20-2017 07:29 AM
Last Post: hoanganhtai
Sazki how to write write protection 93c56 ??? massimo74 2 313 07-17-2017 02:11 AM
Last Post: massimo74
  roof ecu repair - bad resistor network or other component? ori793 0 310 07-14-2017 07:50 AM
Last Post: ori793
