auto to manual conversion ms41
01-17-2018, 11:46 AM
BMW auto to manual conversion ms41
Gotta swap m52b28 from e39 automatic to e36 manual without EWS. My question is, does the ecu switch to manual mode by simple reflashing with manual soft? GM coding from ews is not available so it cant read it from anywhere. Thanks
cardiagova.cz
01-17-2018, 12:47 PM
RE: auto to manual conversion ms41
take a look here
(01-17-2018 11:46 AM)BobbySD Wrote:  Gotta swap m52b28 from e39 automatic to e36 manual without EWS. My question is, does the ecu switch to manual mode by simple reflashing with manual soft? GM coding from ews is not available so it cant read it from anywhere. Thanks
Attached File(s)
MS41.txt
File Type: .txt
Downloaded: 18 times
 Thanks given by: BobbySD
01-18-2018, 04:13 AM
At first sight theres no info about my problem Smile but thank you the page is very interesting
cardiagova.cz
01-18-2018, 09:15 AM
you probably need to read/write full flash and not only partial.
also maybe you need to downgrade from MS41.1 to MS41.0 if WINKFP doesn't want to flash it because of HW number
01-18-2018, 09:46 AM
Program with winkfp using part numbet that belongs to manual transmision. All part numbers could find in realoem.com
01-18-2018, 09:49 AM
it is already 41.0. Its from 1997 I think. Yea I will do it with winkfp and will see if it will be ok. But I know in newer cars with ews even after flash with manual soft, car still looking for auto gearbox and behave like automatic cuz its read coding from ews.
cardiagova.cz
01-18-2018, 12:02 PM (This post was last modified: 01-18-2018 12:03 PM by BobbySD.)
does anybody know what is the zusb for manual sw? hw nr 1429861 and type 1740497
cardiagova.cz
01-20-2018, 11:56 PM
hi
contact me i can do it
STG1 STG2 CUSTOM REMAP NA TO FORCED INDUCTION CONVERSION REMAP&TUNING SOLUTION.
SKYPE: AIMANAD_101
01-22-2018, 12:10 AM (This post was last modified: 01-22-2018 12:15 AM by driiiven.)
use xbytes tool to flash full manual bin and done. Also the coding on an e36 is stored in cluster as well hence why you can disconnect ews and still have car search for egs if you don’t do as I say with full manual bin. The real proper way would be to decode cluster as bmw would build it then car takes care of the rest
  BMW E46 330D AUTO GEARBOX Problem Lunacy 0 450 02-06-2018 01:34 PM
Last Post: Lunacy
  R56 MEV1722 ECU replacement manual/auto problem l0x2 16 2,706 01-03-2018 05:59 AM
Last Post: paco88
  BMW E46 330D 204CV 2004 Auto Gearbox Lunacy 10 3,750 12-11-2017 11:34 AM
Last Post: Lunacy
BMW BMW auto trans to manual gelencserg 4 1,566 10-30-2017 09:46 PM
Last Post: gelencserg
  2006 BMW 750 (E66) Auto Trans Swapping. ernesto125 15 557 09-28-2017 11:54 PM
Last Post: nguyennhatquang
