  • 5 Votes - 2.4 Average
bmw e60 dash needles go crazy
10-17-2017, 10:38 PM (This post was last modified: 10-17-2017 10:50 PM by drugowaz.)
hi,i got strange problem. rpm needle intermitent drop on running engine. if drive in road both speed and rp drops down intermitent.but car runs file.
scanned got errors is cluster
A3AD
A3AE
Some kind komunikation errors
error in kgm module
c907 k-can communication fault.
checked trunk for water.all good.
where could be problem?
its hardware or soft bug?
also owner case and said in morning his battery was drained. no start.today he put new batery
What is the difference between professionals and amateurs? Only amateurs panic.
10-17-2017, 11:56 PM (This post was last modified: 10-17-2017 11:57 PM by ziomal4340.)
RE: bmw e60 dash needles go crazy
Check the connection can as in the schematic
X15003
X15004
Attached File(s) Thumbnail(s)
Supply, instrument cluster.html
File Type: .html
Downloaded: 11 times
 Thanks given by: drugowaz
10-18-2017, 12:01 AM
try to update kombi software,it seems software calibration.
10-18-2017, 12:08 AM
pin 6-7 x16 connector?
10-18-2017, 01:17 AM
Symptoms seem like transposed earth fault check body earth and cluster earth clusters also have self test procedure
10-18-2017, 01:35 AM
But everything else is fine
Why it throws just engine speed messahe fault. No lights on dash. Only those needles drops down.
10-18-2017, 06:07 AM
ive seen this happen when someone did km correction on e90 and data corrupted. he took it to someone who loaded file from another e90 into cas and all worked fine, but every now and again the needles would go bonkers. no idea if he fixed it
 Thanks given by: PedroX5
10-18-2017, 06:50 AM
No.earlier all was fine long time. Not the caseSmile
10-18-2017, 07:55 AM
It would be useful to know if your scan tool live data fails in vehicle and engine speed at the same time as it occurs at cluster maybe check scope pattern of ignition coils and engine position sensor in case you're getting some strange signal effecting cluster also try cluster self-test procedure just to at least eliminate that! look into abs live data regarding communication of vehicle speed from ws sensor
 Thanks given by: KriyenKPp
BMW BMW e60, Can I disconnect the battery for 2 weeks without problems? Rase 4 1,011 02-13-2018 02:26 AM
Last Post: Rase
BMW BMW E60 CIC update/flash SpezDIAG 4 874 02-08-2018 11:24 AM
Last Post: SpezDIAG
BMW Ask for E60 jongpiyachoti 2 609 02-07-2018 04:37 PM
Last Post: jongpiyachoti
BMW BMW E60 MASKn2 Coding drevenga 5 1,050 02-06-2018 07:58 AM
Last Post: iyad.nasser
BMW bmw E60 LCI 2.8xi paddle shifters retrofit coding and zusb Camaro9434 5 2,520 02-04-2018 09:49 PM
Last Post: Camaro9434
