c200 w203 wont start
07-12-2018, 03:54 AM
Hello friends and family,
i am having some issues with a C200 W203 m271, ISSUES below:
Car was starting normally but developed some idle and throttle issues, so the owner decided to take the car to fix and history of the car was: replaced throttle body, airflow meter, now the car worked normally about one month ago according to owner, but now its in my workshop for the following issues below:
1. car not starting with key, it turns the steering lock, so it functions, ignition comes on no codes on the ezs eis esl, but to crank position iii , nothing happens..no crank.
- so i probed to the starter unit and it cranks and attempts to start,it only idles and stay idle when the intake is blocked by hand...now i scanned and found two codes
P2006-1 B2/5b1 intake air temp sensor, signal short circuit to + (p0113)
p2019-2 K40/4K3 (AIR PUMP RELAY) N10/1k0 short circuit to ground (p0410)
now Im faced with resolving two issues, 1.normal starting and 2.engine idling.
I located the front SAM and Rear SAM, and start with fuse checks and relays , but i would really appreicate some expert advise to resolved this problem maybe a fuse and relay diagram or where this issue may be, not everyday we have a w203 in our workshop, thanks in advance guys!!
SmileSmile
07-12-2018, 03:57 AM
RE: c200 w203 wont start
check starter realy and fuse in front SAM
ChiptuningFileService
SwirlFlaps EGR DPF NOX DTC TVA ADBLUE Lambda Immo...
facebook ZenterPerformance
Licensed Winols Damos map packs translate FRT
ORI Kess Ktag CMD Ecutek HP Tuners bFlash Time
 Thanks given by: HestonDiag , Shawnp
07-12-2018, 07:56 AM
Thanks I Checked F52 fuse and S relay, the fuse is a 15amp and it’s working also the starter relay tried another and same thing.
07-12-2018, 09:14 AM (This post was last modified: 07-12-2018 09:15 AM by Rocinante.)
Is the signal to the starter relay coming out of the engine control unit? Do you have a Star Diagnosis system to read the actual values of the engine control unit? Is this a manual or auto trans? Is it recognizing Park/Neutral? Clutch switch?
Don't worry about the idle if you can't get the engine to crank.... Take the diagnostic steps in order... no crank will most likely block the engine running by not turning on the injectors or other means..
________________________________________________________________________________​​______
 Thanks given by: HestonDiag , laco210 , Shawnp
07-12-2018, 11:55 AM (This post was last modified: 07-12-2018 11:55 AM by Shawnp.)
(07-12-2018 09:14 AM)Rocinante Wrote:  Is the signal to the starter relay coming out of the engine control unit? Do you have a Star Diagnosis system to read the actual values of the engine control unit? Is this a manual or auto trans? Is it recognizing Park/Neutral? Clutch switch?
thanks for the reply!! yes i have star Diagnostics unfortunately its not working, so i am temporarily resorting to the Maxidas Ds708 ,
The car is auto transmission, ****note it will not come out of park, usually the owner said it was engaging into neutral but now its stuck in P***
yes i understand other relating issues may cause the idle...
can you advise the steps i should take now factoring in the AT neutral switch?
07-12-2018, 01:52 PM
If it won't come out of park, you need to check and see if the shifter is failing.. you really need an SDS to check codes and control units that aren't communicating.. there is soooo much involved just to get the starter to turn...
 Thanks given by: HestonDiag , KriyenKPp , laco210 , leminhautotek , Mercerwin
07-12-2018, 03:42 PM
Check circ. 15 relays in front Sam. Can we get your Vin please
07-12-2018, 04:45 PM
Per your description check if the signal from the Ecu to the starter works
When you open the key. For all you know there is a short some where
Also get a wiring diagram for reference bro. Hopes this helps
07-13-2018, 04:26 AM
You want to look at relays P and S
Attached File(s) Thumbnail(s)
WebETM Model 203.pdf
File Type: .pdf
Downloaded: 3 times
 Thanks given by: Shawnp
  w203 c220 alternator problem ithyshaam 5 394 Yesterday 11:48 PM
Last Post: HestonDiag
AA Bosch-logo abs light on help c220 w203 bram80 5 572 07-16-2018 07:37 AM
Last Post: bram80
Mercedes Benz MB ML W164 key wont turn after dead baterry kentrinite 4 469 07-12-2018 03:44 AM
Last Post: redangell
Mercedes Benz Mercedes B200 CDi wont go past 120kmph MafiaDON 4 379 07-09-2018 11:15 AM
Last Post: stachu121
  W203 Audio 20 unit, rear left door speaker blown twice Karu 1 205 07-08-2018 12:30 AM
Last Post: webmaster
