discovery 2 ecu immo off
06-19-2017, 12:23 AM
Land+Rover discovery 2 ecu immo off
discovery 2 ecu immo off eeprom 93c66.
06-19-2017, 12:55 AM
RE: discovery 2 ecu immo off
Post dump someone will assist
Ask questions later24
06-19-2017, 01:03 AM (This post was last modified: 06-19-2017 01:06 AM by tonyta.)
(06-19-2017 12:23 AM)tonyta Wrote:  discovery 2 ecu immo off eeprom 93c66.
that is the ecu picture
Attached File(s)
93c66 ecu discovery 2.zip
File Type: .zip
Downloaded: 14 times
06-20-2017, 02:40 AM (This post was last modified: 06-20-2017 02:41 AM by AutoHaus786.)
Here bro...
93c66 ecu discovery 2-OFF.rar
File Type: .rar
Downloaded: 9 times
Cut the ECU Pin 72.
Cut Pin 23 (Red and Black) from IMMO BOX and join Pin to 2 (Black)
Work hard
Play harder
 Thanks given by: tonyta , KriyenKPp
06-21-2017, 01:44 AM
(06-20-2017 02:40 AM)AutoHaus786 Wrote:  Here bro...
Cut the ECU Pin 72.
I wrote the file you sent but i have a problem first i tried to locate for immo box but i coundn't find it only the bcm on the right hard side. the bcm is where i will cut and join? also i don't have the pinout diagram of the ecu. please help me if you have it. thanks alot.
06-21-2017, 08:51 AM
Cut the ECU Pin 72.
ecu pins are numbered on the inside bro...
Work hard
Play harder
 Thanks given by: KriyenKPp , tonyta
  Discovery Media PRO Component Protection magna413 20 6,489 08-08-2017 02:10 PM
Last Post: elguano
Land+Rover Immo off Discovery 2004- alarm box location mimmo258 7 250 07-02-2017 08:00 AM
Last Post: mimmo258
  Immo off Discovery 2 2004 2.5 TDI with BCM mimmo258 2 175 07-02-2017 07:48 AM
Last Post: AutoHaus786
  Discovery 3 ecu swap ivannzowa 6 247 06-12-2017 06:54 PM
Last Post: xginx
  land rover discovery 2016 bcm data corrupted maruti 0 144 06-11-2017 07:25 AM
Last Post: maruti
Land+Rover DISCOVERY II EKA CODE NEED BY DUMP socrate 0 116 06-06-2017 10:07 AM
Last Post: socrate
AA+MHH IMMO OFF + IMMO chip locations + ECU pictures + steeringlock OFF bin + memory info Cirak 69 73,218 05-02-2017 08:15 AM
Last Post: tselis
  Volvo ECU, what is this ECU? Immo off? Fexeus 7 360 04-14-2017 11:21 AM
Last Post: Bosse
  Land Rover Discovery BCU smajchell 0 193 03-07-2017 10:24 AM
Last Post: smajchell
Land+Rover need EKA code for LandRover discovery prof.memet 1 334 02-08-2017 05:04 AM
Last Post: nicmag
