help! no work DAS 2017/12
02-21-2018, 11:29 PM
Mercedes Benz help! no work DAS 2017/12
Greetings to all participant mhhauto!
 Faced the problem after installing xentry 2017/07.
the situation is as follows:
I connect to ml164 2006, Xentry opens DAS and when connecting DAS gives an error that there is no connection with mux. after that I connect to w204 in 2011, ksentry works remarkably.
2017/09 this same mux DAS on ML164 works fine. what to do with DAS 12/2017? where to dig?
serial number of mux is 100925.
Do I need to change the serial number for DAS 2017/12 ????
HELP !!!!!
02-21-2018, 11:31 PM
Chery RE: help! no work DAS 2017/12
your serial 100925 is not blacklisted Rauch15
Thanx 4 all!
___________________________________________________
If I helped you, please press [Image: postbit_reputation.gif] and [Image: postbit_thx.gif] on my post!
02-22-2018, 07:31 AM
Clearly a bad install
[Image: uPMYvg3.jpg]
02-23-2018, 07:38 AM
what is your error when you try to connect in DAS?
02-23-2018, 07:46 AM
Mercedes Benz RE: help! no work DAS 2017/12
(02-23-2018 07:38 AM)bulayooo Wrote:  what is your error when you try to connect in DAS?
my error sounds like this:
Had (1.1) -1.501.9922. in DAS mode.
Initioalization of diagnosis mulltiplexer failed.
02-23-2018, 08:10 AM
look this:
http://mhhauto.com/Thread-Help-Xentry-12...2-DAS-mode
02-23-2018, 08:13 AM
(02-23-2018 08:10 AM)bulayooo Wrote:  look this:
Xentry work
02-24-2018, 05:58 AM
(02-21-2018 11:29 PM)n_nikolaychuk Wrote:  Greetings to all participant mhhauto!
HELP !!!!!
I had same issue with Xentry working and das not connecting, i did a reinstall blocking all the add-ons and now both xentry and Das work fine. I suppose the latest addon released from Daimler causing this problem. Refer this post for more comments from other members,
http://mhhauto.com/Thread-Das-12-2017-Not-Connecting.
If I have helped you please do not forget Thanks + Reputation 41
02-24-2018, 06:08 AM
HELP !!!!!
can you give the link to download addon`s?
Mercedes Benz [XDOS] DAS Call WIS NET F6(HELP) - WIS is not available Solution pesona 42 8,983 Today 02:20 AM
Last Post: skynete
  W212 seat controller not work after change sam BySimlockcu 2 138 06-20-2018 10:41 AM
Last Post: MBENZTECH
Mercedes Benz DAS.License.0.Fix with DAS.Standalone and Old.StartKeyCenter (2018.07) DieTRih 0 342 06-19-2018 08:11 AM
Last Post: DieTRih
  DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 pesona 247 64,600 06-18-2018 10:34 AM
Last Post: audiomeca
Mercedes Benz DAS.License.0.Fix with DAS.Standalone and Old.StartKeyCenter (2018.05) DieTRih 2 1,826 06-17-2018 10:44 AM
Last Post: gokcenxx
