  • 1 Votes - 2 Average
international help needed
01-11-2017, 03:51 PM
I'm needing help on solving this short on a 2006 international 9400i SBA. The problem is I have no power to the cigarette lighter neither dome lights. But the radio is working. I have checked the fuses and they're fine. If I could see a wiring diagram for it I could probably check the circuit for short. Any help would be greatly appreciated.
01-11-2017, 04:46 PM (This post was last modified: 01-11-2017 04:48 PM by IROC.)
RE: international help needed
Cigar lighter is powered by fuse F2-A. Supposed to be a battery source 15 amp fuse. Is there power to the fuse? Is there power through the fuse?
Did you check to see if the wire is attached to the back of the plug or if the ground wire is attached?
 Thanks given by: maquetel
01-11-2017, 05:10 PM
If it is a isx we had one where the wire was broke above the motor cover against the firewall. All the same symptoms like you
01-11-2017, 07:26 PM (This post was last modified: 01-12-2017 06:43 AM by Dcmechanical.)
Try these out
Attached File(s)
9400i.txt
File Type: .txt
Downloaded: 6 times
international.txt
File Type: .txt
Downloaded: 5 times
01-12-2017, 12:23 AM
(01-11-2017 04:46 PM)IROC Wrote:  Cigar lighter is powered by fuse F2-A. Supposed to be a battery source 15 amp fuse. Is there power to the fuse? Is there power through the fuse?
no there is no power to fuse
  International cab controller haggaiautomotive 4 108 02-12-2017 07:58 AM
Last Post: haggaiautomotive
  Need Navistar International Nets 5.5.1 shawn74 88 8,029 02-08-2017 04:01 PM
Last Post: Catdoctor
  International OnCommand 2015 Errors solution bruschino1978 0 78 02-05-2017 05:35 PM
Last Post: bruschino1978
AA+MHH international maxxforce 13 DPF delete? binhminh410 18 17,296 02-03-2017 08:31 AM
Last Post: evervas
  International Navistar Diamond Logic Builder (DLB) Fleet 2015 v15518 + Keygen jahacmm 12 2,527 02-01-2017 06:05 AM
Last Post: cars4megames4u
  Clear check engine light on international maxxfoce 13? asianofthecorrs 6 98 01-31-2017 11:10 AM
Last Post: bennett22
  service max international truckwork 1 99 01-23-2017 09:32 AM
Last Post: tomacejones
  International Diamond Logic Builder v15520 English megashared 10 3,263 01-09-2017 01:27 AM
Last Post: dhillonj
  01 international 4700 abs question/help tomacejones 13 319 01-07-2017 12:12 PM
Last Post: IROC
  I.B.I., International Bearing Interchange Guide wolf864 1 220 01-03-2017 09:03 PM
Last Post: wolf864
