lost VW Caddy ABS coding after disconnect dash
06-19-2017, 04:29 AM (This post was last modified: 06-19-2017 04:40 AM by orange.)
Hi Who can help me with the right ABS coding on this VW caddy
VIN: WV1ZZZ2KZCX103625 License Plate:
Left hand drive 1.6 tdi
Chassis Type: 2K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 40 42 44 46 52 5D 61 69 75
VIN: WV1ZZZ2KZCX103625 Mileage: 148130km-92043miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
40-AC Compressor -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5D-Operations -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
75-Telematics -- Status: OK 0000
Address 01: Engine (J623-CAYD) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PD HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 0870
Revision: --H43--- Serial number: 00000000000000
Coding: 00114014032401080000
Shop #: WSC 00011 888 182020
ASAM Dataset: EV_ECM16TDI02103L906023PD 003003
ROD: EV_ECM16TDI02103L906023FL.rod
VCID: 77F87F43CE6EA6F9D8-8022
1 Fault Found:
7196 - Function Restriction due to Faults in Other Modules
U1113 00 [101] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Mileage: 204331 km
Date: 2017.06.19
Time: 14:46:48
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 47 °C
Intake air temperature: 32 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 11.407 V
Unlearning counter according OBD: 40
Engine speed: 0 /min
Accelerator position: normalized-Accelerator position: 0.00 %
Battery voltage: 11.2 V
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 00000000000000000000000000000000000000
Shop #: WSC 37483 001 1048576
VCID: 7BF06373FA468299BC-802E
4 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 123
Time Indication: 0
Date: 2017.06.19
Time: 14:54:41
Freeze Frame:
Count: 3
Count: 0
Count: 20992
Count: 195
Count: 40192
Count: 0
Count: 0
Count: 0
01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 123
Time Indication: 0
Date: 2017.06.19
Time: 14:54:41
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 123
Mileage: 148135 km
Time Indication: 0
Date: 2017.06.19
Time: 14:54:03
Freeze Frame:
Count: 3
Count: 2
Count: 20992
Count: 295
Count: 40448
Count: 0
Count: 256
Count: 0
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 123
Mileage: 148135 km
Time Indication: 0
Date: 2017.06.19
Time: 14:54:03
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
Component: AC Manuell H19 0304
Revision: 00001016
Coding: 0000004003
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 7F089763E65E9EB990-802A
1 Fault Found:
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 177
Mileage: 106921 km
Date: 2016.03.03
Time: 00:00:06
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 P HW: 5K0 937 086 P
Component: BCM PQ35 M+ 021 0064
Revision: BD021001
Coding: 611A583A80251A6D088000829400816403517288426F8160648087000041
Shop #: WSC 80093 222 69422
VCID: 418CD19BD82A2849A6-8014
Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 04011 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 261211 05 54 0403
Coding: 0230ED
No fault code found.
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag025 H06 0013
Revision: -------- Serial number: 003HL009NCML
Coding: 000000000000000000000000000000003235
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3564B54B94E294E90A-8060
3 Faults Found:
13635840 - Supply voltage
U1011 00 [008] - Voltage too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 163
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 177
Mileage: 106921 km
Date: 2016.03.03
Time: 00:05:21
12674816 - Immobilizer Control Module
U0167 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 177
Mileage: 106921 km
Date: 2016.03.03
Time: 00:00:06
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422LA4000EH
Coding: 5080160000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_VW32.rod
VCID: 70EA445FAB00F1C119-8024
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 2K0 920 865 E HW: 2K0 920 865 E
Component: KOMBI H03 0606
Coding: 180A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
VCID: 306A845F6B80B1C159-8064
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 070112F2003791
Coding: 357400
Shop #: WSC 35110 377 00142
VCID: 3B70A373BAC64299FC-806E
1 Fault Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 123
Mileage: 148135 km
Time Indication: 0
Date: 2017.06.19
Time: 14:46:26
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0606
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADE56378DDC0B1157-803E
Address 40: AC Compressor
Cannot be reached
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.clb
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2109
Coding: 0132144
VCID: 489ACCBF3B10190161-801C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 140 3301
Revision: 00H22000
VCID: 3564B54B5CE294E90A-8060
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 148135 km
Time Indication: 0
Date: 2017.06.19
Time: 14:52:15
Freeze Frame:
Battery Volts: 11.4 V
DD
Temperature: 34.0°C
Count: 9
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.clb
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0132144
VCID: 4798CF83360E167968-8012
Address 5D: Operations
Cannot be reached
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1623
Coding: 030F1859
VCID: 71EC415BA80AF8C916-8024
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 00000000008900393972
Address 69: Trailer Labels: RETROFIT69.lbl
Part No SW: SW0 408 HW: 5F0 07V 010 1
Component: TOWBARMODULE ECS 0010
Coding: 0000001
VCID: 76E672470164DFF1C3-8022
Address 75: Telematics
Cannot be reached
End-------------------------(Elapsed Time: 02:30)--------------------------
06-19-2017, 06:22 AM
RE: lost VW Caddy ABS coding after disconnect dash
no one can help ?
06-19-2017, 08:40 AM
623C600D092203FD4601106E6901EC0413000
06-19-2017, 10:33 AM
You may check this out and get back if interested. Pretty familiar with this one,...
ECU, Coding, Diagnostics & more| Your appreciation = THX + REP 049
  Toyota Allion 2006 All Smart Key Lost mymundo3 0 39 Yesterday 11:05 PM
Last Post: mymundo3
Toyota help lexus all key lost meysen 5 374 08-15-2017 03:08 AM
Last Post: darek
Mercedes Benz Mercedes Viano after dash correction wrong coding Dododo 2 140 08-12-2017 08:06 AM
Last Post: Dododo
Audi AUDI A7 2010 All key lost Ramis 3 193 08-09-2017 04:31 AM
Last Post: Ramis
VW VW Jetta 2015 all keys lost Ramis 32 2,119 08-09-2017 04:25 AM
Last Post: Ramis
VW ABS CODING HG-Automotive 6 1,240 08-03-2017 01:46 AM
Last Post: rabaukee
  Audi A1 2011 Lost Key ABS Steering Wheel Keyproffs 1 124 07-29-2017 08:53 AM
Last Post: Keyproffs
BMW BMW i8 mileage correction , many dtc's after can-filter installed in dash m37h0d 9 387 07-23-2017 12:13 PM
Last Post: m37h0d
VW ABS coding robin_bga 4 260 07-20-2017 01:09 PM
Last Post: robin_bga
Audi Lost data bcm2 oukassi 5 342 07-19-2017 11:08 PM
Last Post: MK2-VRT
