  • 1 Votes - 3 Average
mileage correction bmw f30 procedure
06-18-2017, 10:45 PM
BMW mileage correction bmw f30 procedure
Hi guys,
I would like to know if I can change the mileage on my bmw f30 2014 how work on fem what is the process for change dash fem...
Thank you guys
06-18-2017, 11:26 PM
RE: mileage correction bmw f30 procedure
need many expensive tools to make it good and in all ecus.also need some can filters to installed
06-19-2017, 12:40 AM
(06-18-2017 11:26 PM)ladadens Wrote:  need many expensive tools to make it good and in all ecus.also need some can filters to installed
there is no need filter.
I don't need "thanks" and "rep", just enjoy if i helped you
06-19-2017, 01:01 AM
Who can help me fo change the mileage some time i heart i need can filter some time no whi can help me please
Who alredy change the mileage on this model
06-20-2017, 05:49 PM
BMW RE: mileage correction bmw f30 procedure
(06-19-2017 01:01 AM)kamelartiste Wrote:  Who can help me fo change the mileage some time i heart i need can filter some time no whi can help me please
contact this Guy
http://mhhauto.com/User-kmodel99
Drive Press the Thanks and + If I really Help You.Kolo
06-20-2017, 08:09 PM
100% need can filter
Install can filter in dash
And read eeprom in dash 35160 and change km
Thats it
Mercedes Scn Coding 24/7
Add/Remove SA Codes to Vedoc/DataCard
Retrofit Lights(ILS, Xenon ,Static )
Skye: reshi1233
06-20-2017, 08:23 PM
(06-20-2017 08:09 PM)rashid Wrote:  100% need can filter
Thats it
why u said 100%?
in which modul i cant change mileage?
if i have helped you, please give me a rep + tnx
06-20-2017, 08:56 PM (This post was last modified: 06-20-2017 08:57 PM by Solskier.)
Can blocker is easy to use, but no so good, only blok syncro mileage cas - dash, from others modules still You can read original mileage. One time i heard something about use second can blocker for OBD connector for block read from other modules, it's true? I don't think so it was true.
06-20-2017, 09:03 PM
if you have good tool not need can filter
BR EDDY
DPF Off - EGR Off - LAMBDA Off - EdBlue ))Rest EGS 8HP F serie.
BDC end FEM solution
Skype: Bimermann
Remember the THANKS and + buttons if this helps you... It just makes me feel goodCheer2
 Thanks given by: temsky740
  Mileage correction in ECU/ECM (Harley Davidsson 2014 - Motorcycle) ? m37h0d 5 123 Yesterday 03:03 AM
Last Post: m37h0d
Citroen Citroen C4 2015 Mileage correction Misterwit123 4 94 08-17-2017 07:52 AM
Last Post: andro822
  OBDlink mx - Mileage Correction VR-6 21 37,526 08-11-2017 05:16 AM
Last Post: nedbull
  Bmw F30 328i CAS or FEM ? drugowaz 13 557 08-08-2017 04:22 AM
Last Post: drugowaz
Peugeot please help ,peugeot 208 mileage correction jaro1791 1 129 08-08-2017 01:53 AM
Last Post: tpetrov
  2006 Range Rover Sport Mileage Correction MRDAN 3 127 08-03-2017 06:53 AM
Last Post: KriyenKPp
  Toyota Hilux 2017 Mileage correction zhed 15 580 07-30-2017 06:28 AM
Last Post: teefyg1
BMW BMW X5 E70 mileage correction konrad199915.98 9 276 07-28-2017 12:40 PM
Last Post: eagleone-two
BMW BMW E46 Dashboard mileage correction ronesz 4 217 07-28-2017 03:02 AM
BMW BMW i8 mileage correction , many dtc's after can-filter installed in dash m37h0d 9 399 07-23-2017 12:13 PM
Last Post: m37h0d
