need a help in renault clip
09-22-2017, 05:25 AM
Renult need a help in renault clip
i have logan 2017,I had a light accident,the aibag didnot activated, after that the engine isnot running...there isn't any pulse in ignition coil but there is electricity
I scan by renault clip and I found a fault called (comp) .
what does this fault mean?
I tried to reprogramming to the injector medule by renault clip v167, told me to connect the battery charger with 13.5v , I did that then measure the voltege , I noticed it the same, then I looked at the battery voltage in life data and I found it 13.5v.the problem is:when I want to program I followed the steps then finally the clip stopped to continue and told me that the battery vol. is 12.5v and connect the battery charger to make the voltage up from 13 to 13.5v.
09-22-2017, 05:31 AM
RE: need a help in renault clip
(09-22-2017 05:25 AM)Esso Wrote:  i have logan 2017,I had a light accident,the aibag didnot activated, after that the engine isnot running...there isn't any pulse in ignition coil but there is electricity
i can help you but you have to contact me on PM
regards
Renult Renault Clip Keygen LuisAndre 83 35,736 10-06-2017 03:18 AM
Last Post: george cars
  Renault CLiP - RO code?? Exotica 3 158 09-07-2017 02:39 AM
Last Post: laz79
  Renault CLiP Version 170 FULL Multilanguage Cardoktror 6 974 09-01-2017 03:06 AM
Last Post: Sparks7766
  Renault can clip with Seven 64 bits Amine13 10 5,971 08-22-2017 02:14 AM
Last Post: wilan
  Renault CLIP Version 169 FULL Multilanguage Cardoktror 6 812 07-21-2017 11:41 AM
  Renault Clip Tool Bay Mr Rorry V2.5 Mago7 3 931 07-16-2017 03:16 AM
Last Post: sixcode
Renult Renault Koleos Clip Problem krzemyk 1 292 05-15-2017 09:44 AM
Last Post: krzemyk
  Renault can clip disconnect problem Amine13 21 7,031 03-28-2017 07:45 PM
Last Post: whocristian
Renult Renault Clip Tool looking1977 5 662 03-07-2017 12:27 PM
Last Post: looking1977
Renult Need Help with Can Clip Please someone. KfzWeiss 4 382 02-17-2017 06:32 AM
Last Post: KfzWeiss
