  • 37 Votes - 2.95 Average
no wisnet folder in C:\Programme\EWA or C:\Programme\EWANET - 09/2012
10-24-2012, 12:13 AM (This post was last modified: 10-24-2012 12:21 AM by Ivory2001.)
Mercedes Benz no wisnet folder in C:\Programme\EWA or C:\Programme\EWANET - 09/2012
I installed DAS/Xentry (AppID 252) up to 09/2012 without any errors. The mux is working fine.
So, after that I installed WIS and EPS also up to 09/2012, also with no errors.
I can start the WIS and EPC over the EWA net with the Internet Explorer.
But if I would start WIS over Xentry, Xentry tells me "Wrong value at system.ewanet.standalonepath. Please check the GlobalSystemSettings.properties".
Ok, I look into the file and the EWA section shows me this:
Code:
system.ewanet.ini=C:/Programme/ewa/ewanapi/ewanapi.ini
system.ewanet.standalonepath=C:/Programme/ewa/wisnet/standalone.bat
So, on my hdd is no folder named wisnet with a standalone.bat. I searched the complete hdd. There also no standalone.bat!!!
I think the wisnet app is not installed correctly?!?!?!
How can I fix the problem?
Can anybody help me?
Thanks in advance.
10-24-2012, 12:47 AM
RE: no wisnet folder in C:\Programme\EWA or C:\Programme\EWANET - 09/2012
I happens because you have installed WIS net the wrong way. Let me guess, you installed it the same way you installed the EPC net ? You need to install it as standalone.
Try this :
Remove wis net database via EWA net administration.
Insert or mount WIS net first DVD, and open it. When you open it, run "SDCheck" or "SDSwitch"
That should start installation for WIS net standalone.
Follow the instructions, and it should work.
If you have any other problems please post.
Regards.
10-24-2012, 01:26 AM
Ok...
I'll try this this evening.
"SDCheck" or "SDSwitch" is on the hdd or on the first EPC DVD?
Ok, I'll find this...
10-24-2012, 01:33 AM
(10-24-2012 01:26 AM)Ivory2001 Wrote:  Ok...
"SDCheck" or "SDSwitch" are on the first WIS net DVD.
 Thanks given by: Ivory2001
10-24-2012, 05:27 AM
Ok, thanks.
Should I start \ewa\setup.exe before I run "SDCheck"/"SDSwitch". Or is "SDCheck"/"SDSwitch" enough and it install's me the EWA net admin tool (and somithing like this) to?
Thanks.
10-24-2012, 09:48 AM
(10-24-2012 05:27 AM)Ivory2001 Wrote:  Ok, thanks.
Thanks.
Just run SDSwitch.exe, don't worry about the rest. Let it use defaults if it asks some questions and then select your preferred language and after a while you should have it all.
 Thanks given by: webmaster
10-24-2012, 10:08 AM (This post was last modified: 10-24-2012 10:09 AM by Ivory2001.)
Ok, I install with SDSwitch the StandAlone WIS. And it works as standalone.
After that I install EPC with the EPC-Discs, but the Admin Tool shows me that the WIS-DB isn't installed. So I must update the WIS-DB with the admin tool again...?!?!?
10-24-2012, 11:36 AM
It works.
I run DVD:\ewa\readme\Support\Standalone_mediasens.reg
I installed WISnet Standalone with SDSwitch up to 09/2012
After that, I install ewa with \ewa\setup.exe.
Now the ewa admin tool shows me, that the WIS-DB isn't installed. So I update the WIS-DB via the admin tool again up to 09/2012 and delete the WIS-DB backup with the admin tool.
WIS works now as standalone and via the WISnet.
Thanks to all.
10-24-2012, 08:29 PM
(10-24-2012 11:36 AM)Ivory2001 Wrote:  It works.
Thanks to all.
I've done this too (in the past) but this isn't what you are supposed to do.
This way you are able to make WIS NET Standalone use the EWA NET WIS database (the other way around should not work).
It would be better if others would not start doing the same and start asking a lot of questions for help. WIS NET Standalone should be enough, no need to see WIS database installed from the admin tool as you are supposed to use the Standalone version of it.
I cannot remember if DAS/Xentry linking to WIS still works, can you test it? If it works, I guess there is no harm other than some additional work to run two complete database updates.
Mercedes Benz Why is EWA Server offline all the time ? qqzha3 19 18,775 04-13-2018 12:36 PM
Last Post: werdse
Mercedes Benz EWA installation error mrahman 6 562 04-04-2018 02:56 AM
Last Post: momosam
  Ewa server not able to start 03/2018 mikevanvliet 2 454 04-02-2018 08:14 PM
Last Post: mikevanvliet
  EWA net unknown LAN id Windows 10 patcash 19 14,883 04-02-2018 05:49 PM
Last Post: rap_down
Mercedes Benz C3 bin folder for 03.2014 petitepeste71 36 16,011 01-30-2018 04:20 AM
Last Post: Rocinante
