security acces from comfort module vw passat b6
11-14-2017, 05:22 AM
VW security acces from comfort module vw passat b6
hi friends, i need to program a new ESL with vcds, i have dump from comfort module 95320.
in fvdi login is 8798, i try 08798 but no access.
thanks in advance
Attached File(s)
comfortori95320.rar
File Type: .rar
Downloaded: 5 times
11-14-2017, 06:57 AM (This post was last modified: 11-14-2017 07:14 AM by Bob the builder.)
RE: security acces from comfort module vw passat b6
(11-14-2017 05:22 AM)eprombyxim Wrote:  hi friends, i need to program a new ESL with vcds, i have dump from comfort module 95320.
thanks in advance
Your login code is okay!
By Dana:
Make sure a battery charger is connected so the voltage is maintained.
[25-Immobilizer]
[Adaption - 10]
Leave channel at "00"
[Read]
[Save]
[Done, Go Back]
[Security Access-16]
Enter the vehicle PIN in a 5 digit format.
[Do it!]
[Adaption - 10]
Read Channel 051.
The Stored Value will be 32000. Enter the PIN in the New Value box.
[Test]
Wait | N/A | N/A | N/A Will be displayed. Wait until the ID numbers are transferred into the first 2 boxes. If you aren't sure, be patient and wait at least 30 seconds!
[Save] (Note: if Save is not available and the data in the last step has transferred continue by exiting)
[Done, Go Back]
Check fault codes in all installed control modules and clear them as needed.
11-14-2017, 07:01 AM
thanks in advance
You pin 8798 correct, what avdi tells you, when you enter pin and click "Security Access (CS)"?
Attached File(s) Thumbnail(s)
VW Passat CC Comfort module replacement[Solved] l0x2 8 678 10-29-2017 02:40 PM
Last Post: mitzi
  CS from comfort module dump passat B6 rafal.gt 4 705 10-25-2017 02:04 PM
Last Post: l0x2
Sazki SUZUKI XL7 2008 SECURITY PROBLEM strikeforce 11 873 10-15-2017 10:42 AM
Last Post: thanh1974
  VW PASSAT 3C COMFORT MODULE nikos1 10 4,043 10-10-2017 02:32 AM
Last Post: ur3an
  Holden Vectra security pin mitch04 1 71 10-04-2017 02:23 AM
Last Post: peroogi
BMW BMW CAS3 Comfort Access key kino0924 5 218 09-28-2017 07:40 PM
Last Post: dtbmw
  security byte alexjpjp 18 14,680 09-28-2017 01:00 PM
Last Post: bzykupiotrek
  Opel Meriva 2004 Change used ECU Need Security code please help rosi1000rr 13 494 09-23-2017 02:50 AM
Last Post: rosi1000rr
  vw touareg window comfort function xipsilon 4 132 09-16-2017 04:49 AM
Last Post: xipsilon
Lexus SECURITY KEY SIGN PROBLEM sgtafric 0 103 09-15-2017 09:55 AM
Last Post: sgtafric
