w292 code out airmatic
06-14-2018, 05:01 AM
Wondering if someone could please offer some suggestions on how to code out the airmatic suspension on a GLE43. I am able to change the coding in IGW212 however there isnt an option for steel springs only. I tried changing all coding to "nien" as far as suspension options but still get the warning(airmatic). Im certain there is more to do just havnt figured it out yet. Your input is greatly appriciated. Also I did not power down N53/1 after the change in coding, would that make a difference? Thanks!!
06-14-2018, 07:25 AM
RE: w292 code out airmatic
I think manually will be very complicated. I would try remove 489 SA code and SCN online all control units related to airmatic function
Mercedes Comand/Audio antitheft codes all NTG
Mercedes Garmin Map Pilot Europe navi
Mercedes NTG5-6 Regio Software
 Thanks given by: Rocinante , SST221
06-14-2018, 06:47 PM (This post was last modified: 06-14-2018 06:47 PM by Jake5555.)
(06-14-2018 07:25 AM)A2ua Wrote:  I think manually will be very complicated. I would try remove 489 SA code and SCN online all control units related to airmatic function
This would be the easiest way.
The other way would be to search in the forum:
At mhh somebody mentioned already which ecu needs to be changed to code it out.
 Thanks given by: SST221
06-15-2018, 09:02 AM
Thanks for the info, I have removed 489 sa from IGW212 and will attempt to SCN code the chassis gateway, ESP, IC, maybe EZS?
I have tried numerous attempts to find thread that possible discusses this but I have not been able to find it?
06-19-2018, 09:25 AM
If I remove 489 SA and then go online to SCN code it, wont the original code be written back in?
06-19-2018, 09:56 AM
I think you should try disconnect airmatic ecu first.
If I helped you don't forget 2 buttons, pleaseTup
06-19-2018, 10:57 AM
(06-19-2018 09:56 AM)jkiller1983 Wrote:  I think you should try disconnect airmatic ecu first.
right, I did remove the fuse to the ecu. I will try to get to ecu, thanks!
06-19-2018, 02:59 PM
Was able to accomplish this, without SCN coding. Thanks for all the input!
Mercedes Benz Mercedes W292 replacement of US rear lamps for European jan.kes 3 580 07-15-2018 01:13 AM
Last Post: jan.kes
  Hub and disc run out tolerance i860 22 1,382 07-10-2018 05:56 PM
Last Post: Rocinante
Mercedes Benz Mercedes W292 auxiliary battery jan.kes 3 399 06-18-2018 03:53 AM
Last Post: jan.kes
Mercedes Benz Finding out which MP is my Actors from EPC Jamad 3 266 05-23-2018 11:09 PM
Last Post: Jamad
  W221 airmatic problem ivannzowa 8 762 05-03-2018 12:11 PM
Last Post: Dimss89
