To obtain your registration ID, please send a request to: webmaster@mhhauto.com
Latest news: --- Fuel quantity correction on the injector always the same, why? --- Looking for Damos Simos 18 VAG --- dump virgin for bsi 406 --- Kess / ktag updates --- Need Checksum Peugeot 406 TD 2.1 --- VCM II 93.02 Firmware Downgrade --- DDEC III and DDEC lV works with Ktag? --- Tiguan 2.0 TDI dpf and egr delete --- VW Nav --- 05 honda element. airbag srs nodule. 77960-scv-a911-m1 what chip ? --- Xprog or R270 Programmer? --- W220 Used Instrument Cluster, Star C4 can correct odometer? --- VCDS function requires licensed interface --- software to test ford focus st --- Need original BDM files 03G906021RH 0281014136 --- edc15v damos --- Searching for tune: Audi A6 2.7T --- AIRBAG AUTOLIV PUNTO -51931289- NEED CLEAR PLSS --- actros --- help nissan pin bcm --- Looking for Opcom chine software. --- CUMMINS INCAL IS NO COMPATIBLE WITH INSITE 7.6 --- Need dump A3 2j74y 8L0920900F or E --- Citroen Berlingo 1.6HDI - BSI backup needed! --- opel astra 1.9cdti 150hp stock , need tuning please --- Mercedes c220 2012 diesel navigation system --- need code blaupunkt.rcd310 --- Buy denso adapter --- Sprinter W906 2015 crash --- KTAG HELP!!!! --- 1K0 035 191D RNS300 CODE --- A3 1.9 TDI 105 HP --- Delphi / Autocom No vci found --- PERKINS key please --- IPAS CODE --- Iaw decode 5nf -59f --- ford v serie 6000cd --- outlander 2008. in circuit programming? --- Jaguar XF --- i need a good tune for tdi 140 BKD engine --- Software interface --- calculate CS VIN PIN etc 2007 golf mk5 visteon cluster --- tms 370c036 with xprog --- MB 5.5 AMG Bosch ME 2.8 --- 028906021dk checksum --- volkswagen passat 3c pin --- CORSA D pin --- Grand Vitara DPF off --- help opel vectra c 2.2 petrol problem ignition coil --- Renault Avantime Immo ---
