Latest news: --- VW MED9.5.10 immo off --- [Chevrolet Captiva 2.0] Need DPF OFF --- Ford ids V106.07 --- Kess 5.017 CN EU Red PCB --- help Ford C-Max --- Damos for free --- sprinter air bag 0285011060 --- EGR OFF EVOQUE --- cummins code 2351 --- nisan qasqai blaupunkt need code --- Audi q7 2012 wipers not working after motor change --- EDC17C64 Immo Off 04L906021EL 7542 --- Need a FRF File 4L0910409T 0001 --- sprinter 2007 --- CLA W117 is it possible to deactivate PRE-SAFE? --- need suzuki pin code --- Perkins 1103-1104/1000 series --- F├Čat doblo radio code --- ACTROS MR PLD diagram --- Reliable chip tuner - needed :) --- star sd connect c4 xentry no communication in das --- VW Golf 4 IMMO PIN --- BMW 330D E46 204PS 2004 DDE+EWS SYNC --- LEXUS RC350 Denso V-May USA --- Bmw e60 535da -> e36 335d --- Nissan Visteon 2016 Code needed --- Change Gearbox Auto to Manual on Audi A5 2013 --- ford transit speed limiter off --- Fiat Ducato (Euro Mobil Camper) ECU remap help --- airbag audi 8P0959655N eprom 95640 no file eprom help --- Chrysler PT Cruiser 2008 year TIPM replaced --- Different hardware MIB2 versions Q7 4M? --- How does one convert MB Part Number ECU to Bosch ECU version? --- Grundig F199 CD radio code need please --- Need help with V/max off --- Audi A4 oil level sensor --- fiat freemont dtc off --- fiat marelli mjd 6f3 checksum please!!! --- Opel / GM E78 ECU Bench pinout for ID / Testing --- Colt CZT EDM Tuned File --- DPF off PEUGEOT 407 1.6 HDI SID803 --- IAW 4AF.SM 55196259 Flash --- Dtc Off fiat ducato 2.3 JTD EDC15 --- Citroen C4 Picasso (B78) 2014 - search wiring diagram --- ford s-max 2007 gauges problem. --- DAS NOT WORKING Fault (3.1)-3.515.2136, NEED HELP --- WITECH MICROPOD2 CLONE REGISTRATION --- Configuration File Required For Powerwizard 4.1 (Engine C13) --- Help With ML W166 Regional Code 0 Time --- Nissan Consult 3 ---
