If your a registered member in MHH and your not able to login or recover your account, Kindly contact webmaster@mhhauto.com
Latest news: --- Xentry 2016.12 with C4 on SPrinter --- Need pin code mazda immo box --- vag 1.2dcm3.7 --- I need CIC HDD Image --- p0441 me7 removal --- in a need to Xprog 5.6 XProgDesktop --- ThermoKing Thermo Serv 3.2 --- Request VW Sharan 2.0 TDI Tune --- VVDI MB Tool --- 2011 Mack cxu613 MP7 injectors & sleeves replace --- Mercedes Sprinter EDC17CP10 --- Skoda Octavia A7 Wiring Needed --- Anyone available to connect with TeamViewer for Odis online? --- Please help needed with 2.2HDI EDC15C DPF off --- Dr Gini for BMW --- RT3 New Map 2016/2017 PT ESP --- Cummins ISM Injector testing --- Need Tuning file for Megane II 1.9 Dci 131 hp --- Audi A2 1.4 16V Magneti Marelli IAW4MV - EGR off DTC remove --- IMMO FORD PUMA EEC-V --- pincode 93c76 --- WORKING HOURS TRACTOR --- VW update pre/post CAYC Engine (Passat) --- Ford Transit Wiring Diagrams --- SUBARU LEGACY 2,0 LX lambda sensor/oxygen sensor error --- Ford c-max 1.6 tdci problem. --- Programmer for a newbie user who is learning by himself. --- RADIO CODE for my FORD KW2000, V series --- EDU opel 1.7 --- Citroen Xantia 2.0 Hdi 90PS edc15c2 hw 0281010252, sw 1037359183 more power --- Europe - NISSAN Connect 1 - V7 - LCN NAVI --- e90 2009my no alert sounds,PDC,seatbelts.. --- looking for denso maps (mondeo 2005) --- no Can with Delphi --- Help ecu equivalence edc15c2 --- Kess V2 Genuine Slave to Master? --- opel astra 1.7 CDTI immo off --- Rate my file touran 136 HP tdi Engine code AZV --- code vw mcd --- Rate this tune --- sharan 2.0 140 km dpf egr off please --- free IMMO Universal Decoding v3.2 Immo 800 MB --- DIS_V57 Standalone Install --- w202 not start 24c04 virgin --- [Request]0074486310 cff --- VW Polo 2012 Airbag Crash --- Parts Book and Shop Manual Komatsu SAA6D125-2 --- B-class edc16c32 dpf off --- Help programming with Calterm --- Damos Map pack ECM driver 2011 Ford F350 6.7 Diesel? ---
