Latest news: --- Xentry openshell 12/2015 password...... --- RNS 510 H11 Continental Nand dump --- Peugeot 206 BSI re-virgin --- DAF XF105 Delphy ECU Adblue off --- K+ dcan usb interface --- airbag reset 8200817787 dacia --- Write custom Files pass-thru on ECU with TIS2000 and MDI Clone? --- MB Sprinter DPF and AGR OFF Delphi crd2.xx --- digiprog3 dumps --- All KOMATSU PARTS manuals free --- Volvo v50 cfff fault anybady can help ? --- Porsche Cayenne GTS --- Best software to check checksum question --- Caterpillar Digital Voltage Regulator (CDVR) Full Set of SIS Info --- Wich Chip i need? Audi A4 1.8t with PLCC inside --- Mitsubishi Denso pinout Piasini search for read and write please! --- John Deere 6506 --- SD C4 - loading firmware. --- HELP Coding airbag module IBIZA 6L --- searching someone with hacking skills?odis --- Immo off Temic ZGS001 Mercedes truck --- nissan key boffin needed --- Mercedes sprinter dpf off --- help fiat ulyse --- IVECO STRALIS BOSCH MS6.2 IMMO.off --- What to use for VW Module Flashing - VAS5054 or other??? --- W205 Command DYNAMIC SELECT --- 2221-45 & 3.91 Fix 2017.05 --- Ford New cluster mileage programming --- Cummins ISX CM 870 and CM 871Static Timing --- Autocom VCI FTDI program --- Sudden blank screen, everything else works --- volvo cummins isx 15 2011 ecm pin locationplease --- nissan VQ37VHR skyline workshop manual request --- mitsubishi canter no start --- KESS V2 obd II to sprinter. --- KIA & HYUNDAI --- ezs v211 koplekl pribor prabeg 13000 --- looking for file writer --- W204 wont start --- How to use TechTool Parameter Description ?? --- A4 full bdm read bench --- Ducato 2.8 EDC15C7 Immo & U1600 off --- How to read and write bosch 7.9.8 ecu --- Freightliner mileage --- help dpf toyota yaris edc17cp37 --- Need original file Renault Laguna 2.0DCi manual 150Hp --- GM 6T40 Transmission BDM Pinout Reading - Recovery 24252871 --- Seat leon 180bhp AUQ tune --- Audi A8 3.0TDI 4E0907401D 4E0910402B 0281013189 BDM backup needed ---
