Latest news: --- caddy 2.0 sdi edc16u1 clone --- suzuki ignis odo correction help --- Mercedes PLD immo off A0424460740 001 --- Audi A3 immo3 cluster --- Looking for key programming suggestions --- Please help to make virgin ISN bmw EDC16 DDE to EWS 4.3 --- FiestaST MED17-TPROT --- Help me --- 1.6hdi/tdci Problem. --- Sprinter EDC17CP10 Boot Pin Issue Need Alternative Location --- 6.4 Powerjoke to 7.3 Powerstroke --- Mondeo MK4 EDC17CP42 --- Old Golf 4 IAW4 flash file needed --- 08 E63 AMG Vibration around 1900 to 2100 RPM when Cold --- vw gol plus_ parati --- A4 B7 need pin --- Ford Damos/A2L files --- New Navistar Engine Diagnostics --- Mitchell on demand not working!! --- How to "Run Command" in CLIP --- Kess 2.08 protocol 482 --- Toyota Tarago (Previa) 2001 ACR30 OBD2 wiring --- Workshop Manual Toyota Land Cruiser HZJ1 --- i need can clip cy7c65113c dump file --- immo off fiat mjd8f3.q9 --- Help with FSC Repair kit --- Galaxy '98 MSA15 immo off --- Help with VW GAMMA V (made by SONY: VWZ3Z3) CODE PLEASE --- Mercedes W203 need help --- ACTROS Transmision --- PCR 2.1 update 9980 --- mk4 retrofit e39 --- Backup edc16U34 --- New Holland EC 215 fault code 20? --- mercedes w211 e280cdi DTC and DPF off --- Pin code citroen c4 95128 JC --- ecu swap Volvo v60 T3 2012 --- Insoric dynamometer --- using abrites on c3 or c4 --- Audi A3 8P rebuild Steering wheel with gear switch to MF and gear switch --- RCD510 Blaupunkt --- Ford Connect 2007 EGR off --- DAEWOO IMMO OFF PLEASE --- VITO112 edc15c5 read with Kess obd2 protocol 15 --- vivaro 2007 edc16c immo off 95640 --- Best mileage correction tool on market --- cat et factory passwords wont work for certian perameter --- please i need pinout for nissan A56-Q97 YQ --- Golf 3 Motometer 93S56 Millage Correction --- PTT 1.12-Urgent-Customer Down-Will pay to activate ---
