Latest news: --- 1996 Toyota Crown Majesta --- caddy 2007 dpf off --- Porsche PCM4 firmware --- Nexiq and CAT ET2015A issue --- Daewoo Tacuma Immo Off --- UPA-USB CAN Bus Analyzer software needed --- DDEC V Wiring diagram --- Mitchell on demand install disk --- iveco vmax --- SID208 CITROEN JUMPER --- Volvo Siemens SID803A KTAG pinout --- Corsa 2009 Water Damaged Ecu help needed --- Help Esys no read FSC --- Unlock code stereo Fiat 2015 --- zed bull --- mazda 6 USA 2014 DUMP eeprom fix- pls help --- Xentry das acronis ??????? --- need software Ford all in one --- Need obviously paying reasonable price file egr dpf off mjd8f2.a2/hw00p/9743-A201 --- a4 b8 bcm2 problem --- can sombody help with immo off audi a3 1.8 20vt --- VOLVO_S40_EDC16C34 CEM ECM sync --- SDConnect 09-2016 --- BMW PDC eeprop+flash, Please --- e92 325d randomly stalls at idle --- need code radio --- UPAS - SPA560P50 --- new mectronic dsg- seat ibiza --- Need helpwith my fgtech chip quality. --- audi a8 2005 read/write --- activation xentry --- Delphi 2015.1 by hex2stuff wont connect to bluetooth new VCI --- audi a4 dpf off --- PSG 16 Opel Zafira 2.2 DTI 92kW the resistance of the valve fuel delivery --- MED17.5.21 KESS OBD WRITE --- Nissan Navara Need up engine speed to 6000 revs --- steering wheel of an Audi A7 on an A4 (B8) --- Komatsu Shop Manual --- ibiza 1.4mpi akk engine flash --- Immo off Passat B7 2012 --- Looking EDC7+FFR+KEY PAIRING I'll PAY --- dump 3B0907552AN --- A6 C6 3.0TDI 239HP EDC17CP14 with Galletto V54? --- 2011 North American ML350 navigation update.164 body stile --- 5C0 959 655 AD - 5WK44531 - VW10 - Jetta 2014 - CRASH need clear counter --- Pinout clk w208 ECU --- EDC17CP14 Tprot problem --- Peugeot 607 2.0hdi fab & EGR off --- Mitsubishi ecm change --- MED 9.1 LC/ALS ---
