E90 320i valvetronic failure and good fix to failure. - Printable Version +- MHH AUTO (http://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (/Forum-General-Automotive-Help-Discussions) +---- Forum: BMW Group BMW, Mini Discussions. (/Forum-BMW-Group-BMW-Mini-Discussions) +---- Thread: E90 320i valvetronic failure and good fix to failure. (/Thread-E90-320i-valvetronic-failure-and-good-fix-to-failure) Pages: 1 2 |
E90 320i valvetronic failure and good fix to failure. - ghostrider - 05-21-2011 08:24 AM Recently I had a E90 320i come into my shop with the mil light on and running on half power. A scan of the vehicle indicated valvetronic servor motor internal failure. On testing the valvetronic servor motor I found it to be working. The problem was it was not advancing the valve timing thus the half power of the engine. If you ever have this problem here is a fix that works. Remove the servor motor and. With a screwdriver push the eccentric shaft gear as far back anti clockwise as it can go. Insert the servor motor and connect its 2 pin plug. Them switch the ignition onto position 2 and withing a space of 15 seconds depress the accelarator pedel down to full throttle 10 times and you will hear the servor motor program itself back to factory spec. Re-fit the valve cover and problem solved. I hope you will find this post useful. Any questions just ask me. RE: E90 320i valvetronic failure and good fix to failure. - LeviDenim - 05-21-2011 09:06 PM That is a very good trick to know. I bet it works on other engines with valvetronic from the E90 series. We never got the 2.0 here. The 2.5 and up made it here and they were built in South Carolina except for the M3. RE: E90 320i valvetronic failure and good fix to failure. - ghostrider - 05-21-2011 10:36 PM (05-21-2011 09:06 PM)LeviDenim Wrote: That is a very good trick to know. I bet it works on other engines with valvetronic from the E90 series. Hi there yes this trick will work on any BMW which has valvetronic servor motors to advance the valve timing. This trick was shown to me by the BMW main dealer here in south africa. The main dealer told me that it is a common fault on the the valvetronic engines. RE: E90 320i valvetronic failure and good fix to failure. - LeviDenim - 05-24-2011 04:05 AM Just got an email back from a friend in the Virgin Islands and he loves the fix. He has a car in with the same symptoms. He will be trying this today. RE: E90 320i valvetronic failure and good fix to failure. - ghostrider - 05-24-2011 10:25 AM (05-24-2011 04:05 AM)LeviDenim Wrote: Just got an email back from a friend in the Virgin Islands and he loves the fix. He has a car in Great I hope it all works out for him. Please let your friend know that when he has the valvetronic servor motor out he must move the eccentric shaft as far anti clockwise as it will go before he re-fits the servor motor onto the eccentric shaft teeth/gear. Then also when he comes to the programming in the car via the accelarator peddle he MUST put the pob key into the dash the he MUST touch the start button lightly just so that the dash cluster lights come on. He must the immediately push the accelarator pedel full throttle ten times and listen for the servor motor setting itself while he does it. I hope it all works out for your friend. If he or you have any questions you can reach me directly and immediately via email on: vehicle_info@yahoo.com By the way when he scanned the vehicle what DTC codes did he come up with? Was is valvetronic internal failure and valvetronic solonoid failure? RE: E90 320i valvetronic failure and good fix to failure. - LeviDenim - 05-24-2011 11:11 AM I will check on the codes he got, he was sure it was the servo motor. He has been BMW certified for almost 30 years. He went independent about 3 years ago. I will pass on all the info just to make sure he gets the reset correct. I have not heard back yet, but will send the info to play it safe. Thanks again. RE: E90 320i valvetronic failure and good fix to failure. - LeviDenim - 05-24-2011 03:16 PM (05-24-2011 10:25 AM)ghostrider Wrote:(05-24-2011 04:05 AM)LeviDenim Wrote: Just got an email back from a friend in the Virgin Islands and he loves the fix. He has a car in Success. and it is like a new car
RE: E90 320i valvetronic failure and good fix to failure. - ghostrider - 05-25-2011 12:40 AM Great glad to hear it worked out right for your friend. RE: E90 320i valvetronic failure and good fix to failure. - kocoglu - 06-23-2011 11:11 PM hi, have a customer car i think it can be same problem, its error code is 2A61 DM i am trying to adaptation with gt1 but have error message that can not save to new adaptation values, how can i solve this problem, also do you have same solution? waiting your reply,,, best regards |
