To obtain your Invitation code, please send a request to: webmaster@mhhauto.com
Please Read the forum Rules before you register. Be aware that not adhering to forum rules might result in Banning your Membership.
Latest news: --- Ametek Flash Program Tool v1.05 --- ServiceRanger402307 --- carprog reprogrammed with USBASP??? --- NEED URGENTLY THIS CAT FACTORY PASS!! PLEASE HELP --- MicroCAT Kia 1 2014 --- ORIGINAL IMMOs ECUs DUMPs EEPROMs for all cars --- Help ECU Opel Corsa 1.7DTI --- help updating caterpillar sis --- 0 281 014 909 I search back-up hyundai H1 --- Maxxforce 11/13 regen switch problem --- HELP Vcds HEX+CAN --- launch diagun update 02/2014 --- Help Delphi Soft install Win 8.1 --- Looking for bmw retrofit doc e61 2004 --- please help with dpf of on sprinter --- rover 75 2.0 cdt change ecu used --- VAS5054A HARDWARE ID ERROR --- Mercedes DAS 2010 / 11 Help --- Help needed, EDC16C9-MPPS --- ***SERDAR AKKAN SCAM*** --- Torque Specs ISC CM850 Cummins --- Volkswagen Flash FRF File using VAS-PC --- 2x globaltis instals on same pc? --- VOlVO FH13 fuel - injector diagnosis --- audi concert plus code --- need help for volvo --- ECU's files --- Mercedes BE4716 and BE3100 --- BMW CAS4 5m48H editiong --- Advice please, What is the best tool for trucks diagnosis --- VOLVO FM4 Fuel Data Reader --- Komastsu PC300-7 --- 06R1999999 --- simos 9.1 --- ISID Isss ISTA ISTAP Cloned HDD not active --- Renault Clio III Airbag Reset --- FH12 I-shift tape selector --- Volvo D16 --- mp3 e65 FL not working --- NAVISTAR Fleet_Programming_Expires_12_15_14.exe --- Mercedes Actros BS --- Toyota RAV4 93c57 2007 milage dashes --- rover 214 immo off --- ECU AUDI a6 1995 4A0 907 473 b IMMO EMULATOR --- HITACHI MEC-N201 IMMO OFF --- Panda 2013 airbag internal error --- NEED HELP WITH 2012 GRAND CHEROKEE --- Problem with LEXIA3 mozilla error --- Fiat Croma 1.9 disel ecu EDC 16C39 DPF and EGR OFF --- Porsche 911 PIN from file to key fob program ---
The specified thread does not exist.
