To obtain your registration ID "Invitation Code", please send your request to: [email protected]
If your a registered member in MHH and your not able to login or recover your account, Kindly contact [email protected]
Latest news: --- Blank ECU file info needed for a 2015 Micra --- dddl 8.4 install problem --- BMW ISN from DDE dump --- 8 digit CODE for w62 --- Please help id bobcat EEP location --- John Deere EDL --- PSA --- Chinese , VCads pro --- Emissions testing software --- Disabling static cornering lights with IDS --- 1996 Toyota Crown Majesta request --- caddy 2007 dpf off --- Porsche PCM4 firmware --- Nexiq and CAT ET2015A issue --- Daewoo Tacuma Immo Off --- UPA-USB CAN Bus Analyzer software needed --- DDEC V Wiring diagram --- Mitchell on demand install disk --- iveco vmax --- SID208 CITROEN JUMPER --- Volvo Siemens SID803A KTAG pinout --- Corsa 2009 Water Damaged Ecu help needed --- Help Esys no read FSC --- Unlock code stereo Fiat 2015 --- zed bull --- mazda 6 USA 2014 DUMP eeprom fix- pls help --- Xentry das acronis ??????? --- need software Ford all in one --- Need obviously paying reasonable price file egr dpf off mjd8f2.a2/hw00p/9743-A201 --- a4 b8 bcm2 problem --- can sombody help with immo off audi a3 1.8 20vt --- VOLVO_S40_EDC16C34 CEM ECM sync --- SDConnect 09-2016 --- BMW PDC eeprop+flash, Please --- e92 325d randomly stalls at idle --- need code radio --- UPAS - SPA560P50 --- new mectronic dsg- seat ibiza --- Need helpwith my fgtech chip quality. --- audi a8 2005 read/write --- activation xentry --- Delphi 2015.1 by hex2stuff wont connect to bluetooth new VCI --- audi a4 dpf off --- PSG 16 Opel Zafira 2.2 DTI 92kW the resistance of the valve fuel delivery --- MED17.5.21 KESS OBD WRITE --- Nissan Navara Need up engine speed to 6000 revs --- steering wheel of an Audi A7 on an A4 (B8) --- Komatsu Shop Manual --- ibiza 1.4mpi akk engine flash --- Immo off Passat B7 2012 ---
You are either not logged in or do not have permission to view this page. This could be because one of the following reasons:
  1. You are not logged in or registered. Please use the form at the bottom of this page to login.
  2. You do not have permission to access this page. Are you trying to access administrative pages or a resource that you shouldn't be? Check in the forum rules that you are allowed to perform this action.
  3. Your account may have been disabled by an administrator, or it may be awaiting account activation.
  4. You have accessed this page directly rather than using appropriate forms or links.
Login
Username:
Password:
Need to register? | Forgotten your password?
