  • 3 Vote(s) - 1 Average
🚀[FREE CREDITS] Nexus Tunes – DTC / EGR / DPF / DEF / CAT Delete Tool + FREE CHKSUM
10
(04-03-2026, 12:31 AM)Thamasa Wrote:
(04-02-2026, 11:43 PM)lassimos Wrote: Hello MHH Auto Family! 🔥
I’ve developed Nexus Tunes, a tool specialized in:
  • DTC Delete
  • EGR Delete
  • DPF Delete
  • DEF (AdBlue) Delete
  • CAT Delete
Credit System (Testing Phase):
  • Every new user automatically receives 30 free credits upon registering an account.
  • Each advanced solution (EGR, DPF, DEF, CAT, etc.) costs 3 credits.
  • DTC Delete costs only 1 credit per file (you can remove as many DTCs as you want in the same file).
The tool is practically free during this initial phase. We are not selling credits.
⚠️ Important Notice:
The platform is still in the testing phase. The deletion functions are working well, but the website may experience some instability or occasional slowdowns. Thank you in advance for your patience while we make the necessary adjustments.
I have not released the full list of supported ECUs yet. The best way to check if your file is compatible is to create an account and test your binary directly.
Important Rules for this Testing Phase:
  • All users who register on the site must comment in this thread stating that they have created their account (e.g.: “Registered” or “Account created”). This allows me to verify that you are an active MHH member.
  • If you do not comment here, your account on the platform will be removed automatically.
  • Bugs and issues must be reported directly on the site (there is a dedicated section for that), not in this thread.
  • Users who report a new bug (the first time it is reported) will be rewarded with extra credits.
If Nexus Tunes helps you with your work and you like the results, I would appreciate a thanks + rep on the forum.
This testing phase is open exclusively to MHH Auto members. Users from outside the community are not being accepted at this time.
Just create your account, receive your 30 credits, and start testing your files.
Any questions or suggestions, feel free to leave them below.
Attached file: Nexus.txt (contains the site access and VirusTotal scan)
Let’s test it together and improve the tool! 🔥
Really? another AI bullshit? Like I have seen this UI like 15 time already. The website awful. Why do I need to input stuff like VIN or License plate in there? I was not able to even complete the ecu identification because it just refuses to detect any anything I put in there. Even if this website works I dont think it will have anything to offer. Maybe if you actually spent some time developing a proper website it would not be so horrific.
We understand that the tool didn't work for you this time, and we're sorry about that.
As mentioned before, the platform is still in the testing phase and the server has been unstable. That said, many other users have already had good results and sent positive feedback.
Regarding your post, I'd like to kindly point out that it violates the forum rules. Specifically, Rule #03 (or Rule 1 in some sections): "Respect each other. Flaming / Spamming / Rudeness will not be tolerated."
Calling the work "AI bullshit", "awful" and "horrific" goes beyond constructive criticism and crosses into rudeness. We're all here trying to help the community.
If it didn't meet your expectations, you're welcome to try again in the future when we have more updates and better stability. In the meantime, we appreciate respectful and constructive feedback it helps us improve.
If you have any questions or suggestions in a civil way, feel free to share.
  • DTC Delete
  • EGR Delete
  • DPF Delete
  • CAT Delete
I stand by what I wrote. The platform is purely AI generated. Its not about it not working. My recommendation for you is just creating an actual website that is actually usable. By slacking off on the main thing that customers sees is just stupid. Sorry for souding toxic, but seeing this AI template marketeted as "BEST" or "NEW" is annoying.
Edit:
Found the AI builder you used for the website in the HTML so at least try to hide it better
DPF/EGR/ADBLUE/LAMBDA OFF
STAGE 1/2
Send a PM!
  • DTC Delete
  • EGR Delete
  • DPF Delete
  • CAT Delete
Edit:
Thank you for the feedback.
I completely understand your point. Yes, I used AI to speed up the frontend design and save time. That’s exactly why I did it: to focus on what actually matters. I didn’t try to hide anything about the frontend at all, and there’s no reason for me to hide it because I really didn’t attempt to conceal it in any way. The core software, backend, and all the functional logic were built manually by me, not generated by AI. That’s the part that does the real work (DPF/EGR/ADBLUE/LAMBDA OFF).
I’m offering the whole tool 100% free right now for people to test. Nobody is forced to use it. If it didn’t work for you or you didn’t like the look, that’s totally fine, no hard feelings.
What I don’t quite get is the “stupid” and “annoying” part just because the visual was AI-assisted. The post at the top literally asks for respectful and constructive feedback, so let’s keep it that way.
If you want to give more technical feedback about how the actual software performs (instead of just the website template), feel free to open your own thread or send a PM. I’m happy to read it.
To everyone else reading this: I really recommend testing it yourself and sharing your honest opinion. It’s free, no strings attached.
Thanks again!
Interesting enough
  • DTC Delete
  • EGR Delete
  • DPF Delete
  • CAT Delete
Edit:
Thanks again!
First, there is a diffrence between using AI to asist you when creating a website and using AI to create the website from scratch.
Second, I tried using your website with 5 diffrent ECUs, but all give out "Operation failed" error. Nearly All of them were diffrent cars (2 VAG, 1 PSA, 1 FIat and 1 KIA) read by diffrent tools. From my view as a "customer" I can see that the owner just taped together some AI code and called it a "product".
STAGE 1/2
Send a PM!
(04-03-2026, 12:31 AM)Thamasa Wrote: Really? another AI bullshit? Like I have seen this UI like 15 time already. The website awful. Why do I need to input stuff like VIN or License plate in there? I was not able to even complete the ecu identification because it just refuses to detect any anything I put in there. Even if this website works I dont think it will have anything to offer. Maybe if you actually spent some time developing a proper website it would not be so horrific.
Edit:
Thanks again!
That’s why we have the section called report a error, to you report that type of situation and we solve it from our end, but you think is better act like a person who don’t have nothing to do and come on other people threads say bullshit, make sure you read the whole thread before write anything stupid again, and remember, you are not my costumer, I’m not selling any product I’m giving for free for people test it (that way I help them) and they help me reporting errors so I can grow faster.
That’s why we have mhh to help each other not to tell bullshit like you, you don’t have half of my rep+ and are here wasting my time and flooding the chat.
(04-03-2026, 12:38 AM)lassimos Wrote: We understand that the tool didn't work for you this time, and we're sorry about that.
Edit:
Thanks again!
Everyone on this forum has a right to express their opinion. I told you what I think is bad and what should be changed/fixed. If you are saying that this is is something that you wont be changing its ok. Comparing who has more rep won't help anything. Time will tell if your website has something interesting that will be good enough for the market.
STAGE 1/2
Send a PM!
đź“‹ LAUNCHED UPDATE ON THE WEBSITE/SOFTWARER - 02/04/2026
1. 🌗 Light/Dark Mode Added the option to switch between dark (default) and light theme after login.
2. 🎫 Support Ticket System Users can open tickets when encountering errors or needing manual file processing. Includes direct file upload in the ticket + selection of which solutions are needed (DPF, EGR, DTC, etc.). All tickets are answered within 24 hours. Admin can respond and send the corrected file back.
3. đź”§ New Automated Solution Modules Available Now
4. 📋 ECU Support List (Dedicated Page) A full page listing all supported ECUs per module. "ALL" tab shows every ECU across all modules with badges indicating which solutions each ECU supports. Global search — type an ECU model and instantly see which functions are available. 9 modules listed: DTC, EGR, DPF, IMMO, EVAP, Vmax, CAT OFF, Lambda/O2, AdBlue/SCR.
Complete Supported ECU List (529 models)
Bosch: EDC16C0, EDC16C10, EDC16C2, EDC16C3, EDC16C31, EDC16C32, EDC16C34, EDC16C35, EDC16C36, EDC16C39, EDC16C41, EDC16C42, EDC16C7-C31, EDC16C8, EDC16C9, EDC16CP31, EDC16CP33, EDC16CP34, EDC16CP35, EDC16CP36, EDC16CP39, EDC16CP42, EDC16U1, EDC16U31, EDC16U34, EDC17C10, EDC17C43, EDC17C47, EDC17C49, EDC17C53, EDC17C58, EDC17C60, EDC17C63, EDC17C64, EDC17C66, EDC17C69, EDC17C70, EDC17C72, EDC17C74, EDC17CP01, EDC17CP10, EDC17CP15, EDC17CP46, EDC17CP52, EDC17CP55, EDC17CP57, EDC17CP65, EDC17CP74, EDC17CV41, EDC17CV42, EDC17_C06, EDC17_C08, EDC17_C10, EDC17_C11, EDC17_C18, EDC17_C19, EDC17_C41, EDC17_C42, EDC17_C45, EDC17_C46, EDC17_C49, EDC17_C50, EDC17_C53, EDC17_C54, EDC17_C55, EDC17_C56, EDC17_C57, EDC17_C59, EDC17_C63, EDC17_C69, EDC17_C73, EDC17_C76, EDC17_C79, EDC17_C81, EDC17_C83, EDC17_C84, EDC17_CP02, EDC17_CP04, EDC17_CP05, EDC17_CP06, EDC17_CP07, EDC17_CP09, EDC17_CP11, EDC17_CP14, EDC17_CP16, EDC17_CP18, EDC17_CP20, EDC17_CP22, EDC17_CP24, EDC17_CP27, EDC17_CP42, EDC17_CP44, EDC17_CP45, EDC17_CP47, EDC17_CP48, EDC17_CP49, EDC17_CP50, EDC17_CP54, EDC17_CP58, EDC17_CP62, EDC17_CP68, EDC17_U01, EDC17_U05, EDC7C4, EDC7UC31, DCU17PC43, M7.8.0, M7.8.1, M7.8.8, M7.9, M7.9.4, M7.9.5, M7.9.7.1, M7.9.71, M(G)7.9.8, MD1CC878, MD1CE101, MD1CP001, MD1CP002, MD1CP006, MD1CP032, MD1CP061, MD1CP062, MD1CS001, MD1CS003, MD1CS005, MD1CS006, MD1CS012, MD1CS014, MD1CS018, MD1CS027, MD1CS089, MD1_CP004, MD1_CP014, MD1_CS004, ME(D)17.5, ME(G)17.9.21, ME1.5.5, ME7.1, ME7.1.1, ME7.2, ME7.3.1, ME7.3.2, ME7.3.H4, ME7.4.4, ME7.4.5, ME7.4.6, ME7.4.7, ME7.4.9, ME7.5.10, ME7.5.20, ME7.5.30, ME7.6.2, ME7.6.3, ME7.6.4, ME7.7.0, ME7.8.1, ME7.8.8, ME7.9.10, ME7.9.20, ME7.9.3, ME7.9.51, ME7.9.52, ME7.9.7, ME7.9.7.1, ME7.9.71, ME7.9.9, ME9.0, ME9.1, ME9.1.1, ME9.2, ME9.2.1, ME9.2.2, ME9.6, ME9.6.1, ME9.7, ME17.0.2, ME17.0.3, ME17.1.1, ME17.1.6, ME17.2.42, ME17.3.0, ME17.5.22, ME17.5.26, ME17.5.6, ME17.7.1, ME17.7.20, ME17.7.3, ME17.7.6, ME17.7.8, ME17.8.31, ME17.8.32, ME17.8.33, ME17.8.5, ME17.8.8, ME17.8.8.1, ME17.8.xx, ME17.9.1, ME17.9.11, ME17.9.12, ME17.9.13, ME17.9.2, ME17.9.20, ME17.9.21, ME17.9.23, ME17.9.51, ME17.9.52, ME17.9.53, ME17.9.55, ME17.9.56, ME17.9.6x, ME17.9.61, ME17.9.64, ME17.9.7, ME17.9.71, ME17.9.8, ME17.U.6, MED7.1.1, MED7.5.11, MED7.6.1, MED7.6.2, MED9.1.x, MED9.1.1, MED9.1.2, MED9.1.3, MED9.1.4, MED9.1.5, MED9.5, MED9.6.1, MED9.7, MED17.0, MED17.0.1, MED17.0.7, MED17.1, MED17.1.1, MED17.1.11, MED17.1.21, MED17.1.27, MED17.1.6, MED17.2, MED17.2.2, MED17.3.0, MED17.3.1, MED17.3.3, MED17.3.4, MED17.3.5, MED17.4, MED17.4.2, MED17.4.4, MED17.5.1, MED17.5.2, MED17.5.20, MED17.5.21, MED17.5.25, MED17.5.5, MED17.6.9, MED17.7.1, MED17.7.2, MED17.7.3, MED17.7.3.1, MED17.7.5, MED17.7.7, MED17.8.10, MED17.8.2, MED17.8.31, MED17.8.32, MED17.9.3, MED17.9.63, MED17.9.64, MED17.9.7, MED17.9.9, MEDC17.9, MEV9.2, MEV17.2, MEV17.2.1, MEV17.2.2, MEV17.4, MEV17.4.2, MEV17.4.6, MEVD17.2.2, MEVD17.2.3, MEVD17.2.4, MEVD17.2.5, MEVD17.2.6, MEVD17.2.7, MEVD17.2.8, MEVD17.2.9, MEVD17.2.G, MEVD17.2.H, MEVD17.2.P, MEVD17.2.x, MEVD17.4.2, MEVD17.4.4, MG1CA007, MG1CA811, MG1CP002, MG1CP007, MG1CS001, MG1CS002, MG1CS003, MG1CS008, MG1CS011, MG1CS015, MG1CS016, MG1CS017, MG1CS018, MG1CS019, MG1CS024, MG1CS026, MG1CS028, MG1CS031, MG1CS032, MG1CS036, MG1CS040, MG1CS042, MG1CS047, MG1CS049, MG1CS055, MG1CS080, MG1CS111, MG1CS201, MG1CS221, MG1UA008, MG1UD008, MG1UP008, MG1US008, MG1US018, MG1US708, PSG16, Delco E86
Continental: 5WY8, EMS2204, EMS2205, EMS2207, EMS2211, EMS2212, EMS2213, EMS2214, EMS2215, EMS3110, EMS3140, Easy U2W, Easy U3.6, GPEC2, GPEC2A, GPEC3, GPEC4, GPEC4LM, MPC5554 2MB, MSD80, MSD81, MSD85, MSD87, MSV70, MSV80, MSV90, SCE60, SDI3, SDI4, SDI6, SDI7, SDI8, SDI9, SDI10.1, SDI10.2, SDI10.3, SDI10.4, SDI21.1, SDI21.2, SDI21.3, SIM2K-51.4, SIM2K-140, SIM2K-141, SIM2K-143, SIM2K-240, SIM2K-241, SIM2K-242, SIM2K-245, SIM2K-250, SIM2K-251, SIM2K-253, SIM2K-258, SIM2K-259, SIM2K-260, SIM2K-261, SIM2K-341, SIM2K-D160, SIMK-31, SIMK-41, SIMK-43, SIMK-47, SIMOS 3, SIMOS 6, SIMOS 7, SIMOS 8, SIMOS 9, SIMOS 10, SIMOS 11, SIMOS 12, SIMOS 15, SIMOS 16, SIMOS 18, SIMOS 19, SIMOS PCR2.1, U2.5W
Siemens: MS43, MS45, MSS60, MSS65, PPD1.x, SID201, SID202, SID203, SID204, SID206, SID208, SID209, SID211, SID212, SID213, SID305, SID306, SID307, SID309, SID310, SID321, SID803, SID803A, SID804, SID807, SID807EVO, SID901, SID902, SIM28, SIM29, SIM210, SIM266, SIM271DE, SIM271DE2.0, SIM271KE, SIM271KE2.0, Simtec71.5, Simtec71.6, Simtec75, Simtec76, Simtec81, Simtec81.1, Sirius D42, EMS2101, EMS2102, EMS2208, EMS2302, EMS24xx, EMS2510, EMS2511, EMS3120, EMS3125, EMS3150, EMS3155, EMS3160, EMS3161
Delphi: CRD2.x, CRD3.x, CRD11, DCM2.7AP, DCM3.2, DCM3.3, DCM3.4, DCM3.5, DCM3.7, DCM3.7 AP, DCM3.7AP, DCM6.1, DCM6.2, DCM6.2 AP, DCM6.2AP, DCM7.1 AP, DCM7.1A, DCM7.1AP, DDCR, MT20U, MT20U2, MT22, MT22.1, MT22.1.1, MT22.3, MT38, MT60, MT60.1, MT62, MT62.1, MT62.1G, MT62.1U, MT80, MT80.1, MT86, MT92, MT92.1, MT92.1E, MT95.1, 6.2A, 6.2AP, 6.2C, 6.2V, 7.1B, 92.1E
Denso: Gen1, Gen2, Gen3, Gen4, MB279700-95xx, MB279700-96xx, P3, P4, P5 (MB279700), R2A/R2B, RF7/RF8, SH1x, SH7055, SH7058, SH7058(S), SH7058S, SH7059, SH72531, SH72543, SH72546, VEA Diesel, VEA Gasoline
Delco: E37, E38, E39, E39A, E67, E78, E80, E82, E83, E84, E86, E87, E88, E92, E98, MT35E
Marelli: IAW4GF, IAW4SF, IAW5SF, IAW7GF, MJ8, MJ9, MJD6, MJD6F, MM8GMF, MM8GML, MM8GSW, MM9GFH, MM10JA
Hitachi: RH850, SH705507N, SH705513N, SH705519N, SH705520N, SH705821N, SH705822N, SH705823N, SH705828N, SH705830N, SH705927N, SH72531, SH72533 Gen1, SH72533 Gen2
Kefico: CPEGD2.20.1, CPEGD2.20.2, CPEGD2.20.3, CPEGD2.20.4, CPEGD3.20.1, CPEGD3.20.2, CPEGP2.10.1, CPGDSH2.26.1, CPGDSH2.26.3, CPGPSH2.14.1, CPGPSH3.26.1, KME1.9.3
Temic: AL551, AL552, DQ200, DQ250, DQ380, DQ381, DQ400, DQ500
Visteon: EEC-V, EEC-VI (1MB), ESU-121, ESU-131, ESU-411, ESU-418
Motorola: NGC3, NGC4, NGC5
Mitsubishi: Gen3, MH8106F, MH8115F, MH8304F, MH8601F, MH8630F
Transtron: SH7058, SH7059, SH72533, SH72544, SH72546
AECS: FC-34, FC-50, TR20, TR40
LinControl: LE4AP, LEC4AF
Valeo: V42
Ssangyong: DCM6.2, DCM6.2AP
We are working everyday to add new ECM Modules on it, please if you have a recomendation login on your account on the website and give us a recomendation se we can work update it the soonest possible, not just about ecm but about Website upgrades as well.
NEW UPDATES COMING SOON
[font="MHH Font", Calibri, sans-serif]Registered[/font]
Users browsing this thread: resitelmaci, 3 Guest(s)
