  • 6 Vote(s) - 2.33 Average
01 ml430 abs problem
2001 ml 430 dtcs c1401 high pressure/ return pump 016 a7/3ml, in esp. tc does not communicate. bas c1025 can signals abs not available. already replaced abs module. when dtcs occur lights come on and abs pump activates. any ideas?
C1401 mostly calls for replacing the brushes in the ABS motor. The brush size is L5-5H.
Before doing that replace K25 relay with a similar one from the fusebox & see if the code is still there. If still there, check the electrical connector for the ABS pump/motor. If you had a leaking washer reservoir, the wires could be corroded. If the wires/connector is ok, change the brushes.
Sort out the brushes first.
Art Tup
So is this permanent or sporadic DTCS?
As I remember sometimes a wiring harness gets damage under a left fender.
Could be also motor brushes.
when the fault happens the abs pump stays running. even with the key out
Sounds like the pump relay is shorted. There is no way that pump should run with the key out. The shorted relay usually damage the brushes.
(03-04-2017, 02:56 AM)jbarikos Wrote: when the fault happens the abs pump stays running. even with the key out
In post #2 , I suggested to replace relay K25 with a similar one from the fusebox for diagnostic purposes.
Art Tup
