  • 20 Vote(s) - 3 Average
2004 dodge programing
2004 dodge need to reprogram another computer for it
do i need drb 111, or drb emulater, or witech
vin as follows 3d7lu38c24g208745
any help would be appreciated
thank you in advance
hello you will need drb3 or drb3 emulator, micro pod is for 2006 to 2015 vehicles CAN protocol I have them both for complete Chrysler coverage its a very simple process you will need the pin code if it has chiped key as well you can also use the autel maxysys or mini I recommend this for the price and the capabilities you cant beat it.
step 1 go to WCM menu
step 2 go to special functions click on replace pcm
step 3 enter pin
step 4 update vin with the one stored in WCM its automatic promp
step 5 WCM will transfer secret key
step 6 cycle key
step 7 go to pcm
step 8 check mileage under special functions and update mileage
DONE!
Good luck let me know if you need assistance
Thanks given by: truckwork , traxx951
(12-01-2015, 08:34 PM)truckwork Wrote: 2004 dodge need to reprogram another computer for it
Hi, if you are using a used pcm you can also just rewrite the vin number to the pcm, a few tools are capable of doing this function and you will not need a pin code. snapon,autel, drewtech tool box also has the function, abrites commander advi or fdvi both can do it. just turn key on do not try starting/cranking the engine , change the vin with the vehicle's original vin, turn key off and back on , wait for the security light to go out then start vehicle. hope this helps.
07-04-2020, 03:12 AM
Dodge
06-23-2020, 05:00 PM
Dodge
05-22-2020, 03:17 AM
05-01-2020, 09:36 AM
