  • 5 Vote(s) - 2.6 Average
2005 MB C240 key (immo)
Hi guys,
one of my customer asked me if I can program a new key into his 2005 C240.
I know this can be done with VVDI but I dont have the tools.
I only have XentryPT, x431 scanner, X100 tab, and carprog.
Is there any way to make a key with one of these tools ?
I don't think so but just asking,
thanks!
Hi.
I also would like to know if you can do it with DAS and C4?
I was looking in Star but it says it needs some green workshop key 533 what is that?
Thanx.
(02-24-2017, 01:47 AM)MrPhil Wrote: Hi guys,
thanks!
Hi,
Basically you need tools for :
1-Reading Motorola processor in EIS, (Electronic Ignition Switch)
2-Extract keys data by calculator ( skc)
3-You need NEC key programmer or any tool can program the mercedes keys small or big( with Motorola) or BGA
4-You should know soldering skills .
Good luck
Thanks given by: MrPhil , craig coopen
(02-24-2017, 02:28 AM)fenir Wrote: Hi,
Good luck
no problem with soldering skills...
I've seen videos where someone program the whole thing with his VVDI, without soldering anything... is it possible ? ...
how about VVDI clone ? is it reliable ?
EDIT .. I only see VVDI prog clone.. no VVDI BGAFing20
Good luck
I've seen videos where someone program the whole thing with his VVDI, without soldering anything... is it possible ? ... EDIT .. I only see VVDI prog clone.. no VVDI BGAFing20
This job depends to the devices and tools you have, as I told you , you need to read EIS and calculated key data and tool to write data in the key, if you can do it without soldering will be good.
Thanks given by: MrPhil , craig coopen , daxxer
