Thanks Given: 66
Thanks Received: 41 (32 Posts)
345
Threads:
112
owner brought by a new computer, key, fuse block set
installed and same issue, although now there is a some more lights on, on the cluster
Big boy is still parked here
Thanks Given: 66
345
Threads:
112
Some progress...
checked transmission temperature sensor voltage (should be 5 Volts) only 1.1 volts.
disconnected TCM - car now cranks....good progresss
Won't start.
Same codes, fuel pump looks like it is giving enough pressure.
Checked Synchronization Status - Synchronization Failed
What do I do about that?
453
Thanks Given: 444
Thanks Received: 1578 (376 Posts)
670
Threads:
57
13
12-08-2016, 11:40 PM
(This post was last modified: 12-08-2016, 11:42 PM by efka.)
For everything you did you are shooting birds in the sky. If key turns and there no start situation you firstly must check Drive authorization. EZS, ESL, ME, EWM, NAG1(transmission) If all are yes (that I do not think so) then simply go and check starter circuit. (if not - go to that particular component and fix the problem. This car is primitive. For everyone on other side of the pond - quit suggesting BGA tools or so - 2008 sprinter is Mercedes indeed but with one significant difference - it has TRANSPONDER KEY as first generation ML. (or sprinter like) though rest of drive authorization is hash based -aka FBS3. Not like Euro Sprinter with plastic key.
Get me DRIVE AUTHORISATION screen and I will pinpoint you proper way.
Thanks Given: 66
345
Threads:
112
Control Module CDI is Activated - YES
Control MOdule CDI is personalized - YES
Start Enable - YES
Synchronization of control modules EZS and CDI is being performed - NO
Test Counter of control module CDI - 0
The Transport protection of control module CDI is detached - YES
453
Thanks Given: 444
670
Threads:
57
15
12-09-2016, 12:23 AM
(This post was last modified: 12-09-2016, 12:32 AM by efka.)
What about tranmisssion? Judging by what you wrote you have problem with either VGS ecu , or transmission itself. Though your shifter is in parking your actual gear might be not (linkage). Open plastic ecu box, look inside might have it full of oil this happpens constantly with leaking 16 pin connector.
Actual values to check for starter in engine ecu drive authorisation. "Start enable" and dont play stupid games put back original set _ ezs, esl, engine ecu in the car. Your ezs is a gateway in your sprinter and has most of configurations in it
453
Thanks Given: 444
670
Threads:
57
1. you have your answer in my last post. And BTW your temp sensor is resistor based..... YOU HAVE problem with transmission (either linkage or valve body) when you disconnect 16 pin it VGS goes into limp mode and alowes you to crank otherwise it does what it suppose to do based on values from valve body. Valve body in that trans 922.6 is purelyelectro mechanical - all brains are in VGS
