To obtain your registration code or if you are not able to recover your MHH account, kindly contact [email protected]
MHH is in-compatible with Internet explorer!
  • 1 Vote(s) - 3 Average
2016 peterbilt
I have a 2016 Peterbilt with a Cummins. Keeps go No into regen when pto is on. The Cummins end is fine, is this programmable through the peterbilt side? If so does anyone have the software I need to do this?
(05-30-2018, 04:59 PM)Rjpierma24 Wrote: I have a 2016 Peterbilt with a Cummins. Keeps go No into regen when pto is on. The Cummins end is fine, is this programmable through the peterbilt side? If so does anyone have the software I need to do this?
ISX15 CM2250? There is an option under features and parameters for allowing regen with the PTO engaged. Mine does not show it, because this is a simulated ISX CM870, but on the 2250's its here.
If you've already gone that route, verify the engine ECM is receiving a command that the PTO is engaged.
Attached Files Thumbnail(s)
You can do a force regen in c$lterm
Insite  8xxx Fleet Counts & Zapits
DDDL 8.09
Jpro 2019 2018
CAT ET 2019A
G̷h̷O̴s̴T̴m̷A̶n̸
07-10-2019, 07:16 PM
06-12-2019, 11:25 PM
06-12-2019, 05:54 AM
04-29-2019, 09:23 PM
