kyomie
Location OfflineJunior Member
Thanks Given: 0
Thanks Received: 1 (1 Posts)
I have a 21 Suburban I just put a used cluster in from a 22 model. The issue I'm having is that the "Service 4WD" light is on. I wanted to know if there is a way to turn this off?
Any help would be greatly appreciated.
131
Thanks Given: 71
Thanks Received: 485 (413 Posts)
1,107
54
Try to sps update it with right configuration
Airbag Crash Resets
Mail In UK only Airbag Crash Reset
131
Thanks Given: 71
1,107
54
10-29-2024, 06:03 AM
(This post was last modified: 10-29-2024, 06:05 AM by domtorredo.)
Think on gm its was called ipc
Just make sure vin in ipc is same as your cars one otherwise try to manually enter your cars vin when it asks if its correct
Airbag Crash Resets
