Hello everyone, decided to make a post in hopes of helping someone out in the future. On the modern dodge trucks 2019 and up I believe the security/immobilizer modules require security credentials such as NASTF to purchase a key code which changes after 12 hours. Said key code will allow you to program RFhub and key fobs with WiTech. Dealer can provide key code but that will only work if you are registered as a dealer. Aftermarket users will need a different code only accessible with security credentials. Let me know if anyone has any questions. It would be cool if someone could create a program that tries all possible combinations since it is a 4 digit code/ something similar to the program used to crack WiFi passwords.
Thanks given by: LOCKCRUZ
