Thanks Given: 35
Thanks Received: 44 (5 Posts)
105
25
Thanks for all the input
I found that the eis could be read by obd and not by I R so I presume there is something wrong with the eis
147
Thanks Given: 15
Thanks Received: 548 (131 Posts)
344
52
Check your motor, is it original?
If not the original, replace an original motor, I have encountered the same problem
Thanks Given: 35
105
25
12
02-09-2017, 02:51 AM
(This post was last modified: 02-09-2017, 02:55 AM by Zain.)
eis issue solved the coil was broken i managed to solder it now it can be read using ir
after that i tried to operate the esl on the bench i could hear a clicking but no operation of locking
Now when I read the esl it says it is in damaged
please help
99
Thanks Given: 100
Thanks Received: 384 (239 Posts)
625
31
replace coil with new.It produces voltage opposite to the original direction.
ECU-REPAIR-KEYS-IMMO-ABRITES FULL MERCEDES-ALFA-PSA GROUP-VW-ORIGINAL XPROG-UPA ENIGMA-MANY OTHER
Every days a schoolday
Thanks Given: 35
105
25
Is there any way I get get support from vvdi ,If they guide on the procedure it will be a big help
Thanks Given: 35
105
25
Hi
I renewed the eis and adapted esl it is working .
The key I got with the car is working I would like to know if the spare key of the car will work too or some other procedure will have to be followed
