Hello
Ive changed rear sam 2-3 times did scn online all still have one problem in all
Rear blinkers fault in ic
But blinkers works good normally this problem is solved in vediamo
When i do the correct codings then no fault in ic but blinkers also stops working
One rear lamp is eu and one is ece
SamR is not correct number as in car should be
I have another same car when i use its sam all good
But other sams should work also
Anyone have any idea?
Mercedes BENZ CODING 223/254/214/206 STAR3 ECUS
MERCEDES BENZ CODING
JLR CODING AND PROGRAMING
Region Conversion & MAP PIN: NTG 4.5/4.7/5/5s1/5.5/6/7/GEN20x
