A6 2.7 TDI 2005 turbo actuator adjusting
I have an Audi A6 2005 year 2.7 TDI  quattro  BPP engine.
I will replace turbo actuator- the old one is bad and I already have a new one.
I read in the manual that I need the VAS 6395, but I dont have it.
Does anyone have a good advice or how to set up the new actuator, so the car will work without problems?
can a VAG CAN PRO 5.5.1 clone help adapt ? i see that the VCP official site has an option (Adaptation of turbocharger in 2.7 / 3.0TDI engines)
Best regards
No need eny special tool diag. Only connect actuator with screws loose! Then ignotion on acutator stay on under stop posotion. Rotate with acutator to small screw on tilting blades. Tighten the 3 screws and you're done
Thanks given by: PUCVAL
ony possible with
VAS 6395 and not obd ,direct on the turbo
no it cant
,dont waste your time
(11-11-2019, 01:46 AM)vas100 Wrote: No need eny special tool diag. Only connect actuator with screws loose! Then ignotion on acutator stay on under stop posotion. Rotate with acutator to small screw on tilting blades. Tighten the 3 screws and you're done
Does this method work?
(11-13-2019, 03:27 AM)PUCVAL Wrote: Does this method work?
Yep, tested many times Smile
If I helped you, press Thanks & Rep+ buttons.
VW
03-19-2020, 03:38 PM
02-14-2020, 07:01 PM
VW
11-14-2019, 10:52 PM
11-13-2019, 09:05 AM
