ABS module clone
Hi guys , I have a Chevrolet cruze 2012 , 2.0 diesel engine. I have some problems with my abs unit so I have buyed another from a donor car. Can u pls help me,what tool do i need to clone the old unit ? Will it work or i have to buy a new one. I have problems with the electronic side of the abs module.
Thank you.
Rep+Thx if i helped. Kolo
“A man’s true wealth is the good he does in this world.”
If at all you need programming after fixing the abs, pm me
Thanks given by: eduardpetrus
I just programmed a 2013 equinox a local independent changed out the EBCM/BPMV with a used unit.. Yeah they did shatter the connector and didn't have it plugged in all the way so it didn't even start but after I fixed all that I was surprised that sps2 was able to program the used unit with no issues.
Checked and the ebcm reads the correct vin now and the B3902 00 for Incorrect Immobilizer Received went away as well..
I'm waiting now on authorization to go after what I suspect is the the original problem and it has a bad master cylinder.
Opel
05-30-2026, 08:29 PM
10-15-2024, 10:38 PM
03-05-2024, 10:46 PM
