Thanks Given: 391
Thanks Received: 62 (43 Posts)
738
240
I need ACDelco SPS GM programming to update, reflash, reprogram various GM control modules on the bench.
what interfaces, cables do I need for this ?
and where can I buy login to ACDelco for good price ?
161
Thanks Given: 226
Thanks Received: 1144 (153 Posts)
581
115
u cant flash sps on bench
1,010
Thanks Given: 124
Thanks Received: 2141 (437 Posts)
1,342
34
if want help with portal sever GM contact me .
12
Thanks Given: 34
Thanks Received: 66 (50 Posts)
119
You'll need a mdi/mdi2 or j2534 passthru tool, obd socket, wiring with various plugs for BCM, ECM and any units you want to add to it
79
Thanks Given: 273
Thanks Received: 517 (403 Posts)
1,331
12-29-2020, 09:01 PM
(This post was last modified: 12-29-2020, 09:02 PM by liviu2004.)
Go hack a vehicle at the scrap yard, get what plugs and wires you need. Fix a 35mm rail on a cupboard wood, stick some Weidmuller push-in double terminals and start wiring. Get a stable bench power supply, preferable adjustable current limited, example Tektronix PWS2326. Set max voltage to 14.4A, current to your needs, I keep it at 3.5A in case I mess something up in the wiring.
Knock 2 relays and sockets from a car, make yourself an ecu relay and ignition relay.
Once done, be proud, make a picture and let us enjoy it.
