ASTRA J POSSIBLE COPY IMMO DATA?
hi, i have a astra J that someone made swap from 1.3 cdti to 1.7cdti.
now in BCM have many error and dont work many thinks, its possible pass immo data from donor BCM to original BCM?
So i need to copy only immo data ( key data ) from BCM that start car to original BCM
regards
ASTRA JJ.rar
1.66 KB
PRESS REP BUTTON if helped ListenListen
(08-12-2024, 10:14 PM)tigre Wrote: hi, i have a astra J that someone made swap from 1.3 cdti to 1.7cdti.
regards
you need to reset PCM and program with PIN car
mercedes retrofit,coding,programming,AMG menu,CARPLAY
FORD (remote coding programming) help
opel Coding programming help
JLR services
regards
i have try but after says on ecu "key not programed"
try several times
try several times, always :~
P0633-00 immobilizer key not programmed
06-11-2026, 08:22 PM
