AdBlue countdown/mileage help
Hi everyone, tried resetting the AdBlue countdown/mileage via diag (Launch) on a 2021 Kangoo/Citan 1.5dCi, procedure finishes/says ok but counter stays locked. Can someone fix/clear the anti-start counter in this full flash/eeprom dump?"I'm not looking for anything for free.
https://drive.google.com/drive/folders/1...drive_link
I was wrestling with one of those yesterday—it's a piece-of-shit Renault that just won't cooperate.
(09-25-2026, 05:25 PM)gcs190 Wrote: I was wrestling with one of those yesterday—it's a piece-of-shit Renault that just won't cooperate.
Did you manage to sort it out? A member here offered to do it online for me, but I don't have the tool to connect.
Could you tell me which tool you used to do it? I haven't been able to reset it with anything for five days now.
With some modifications in Monaco it can be used for that, but I didn't try it that way, I worked directly with UDS commands, in any case it didn't respond just like it doesn't with xentry.
In any case, I think it can be done with Renault Clip.
Hello, when the Citan first came out with adblue Mercedes Dealers had the same Problems being unable to reset it with Xentry. I remember a colleague telling me about it but don't remember the exact routine.
It was either
Empty the Adblue Tank> turn on Engine for 2 Minutes> turn Engine off> turn ignition on> Fill Adblue> reset Fault> turn Engine on 2 mins> reset Fault
Or
Full Adblue Tank> turn Engine on for two minutes> turn Ignition off and on> empty Adblue> turn Engine on for two Minutes> turn ignition off and on> refill Adblue> delete Fault.
I think the Ignition needed to be off for 60 seconds and maybe the Fault needs to be deleted at the beginning aswell. But it was empty Adblue and leave Engine running for two minutes in some way.
Xentry Online and Renault ASOS Online wouldn't work—neither managed to reset it. I even tried emptying the tank and filling it halfway, but nothing happened; apparently, it doesn't use a mechanical float but operates based on pressure inside the tank, which is where the problem arises. In the end, I just disabled it, and it's working great.
Hello, in my case with the Renault, reflashing the DCU unit helped to remove the range display.
Thanks given by: AutoVexa
(09-23-2026, 11:52 AM)dani1605 Wrote: Hi everyone, tried resetting the AdBlue countdown/mileage via diag (Launch) on a 2021 Kangoo/Citan 1.5dCi, procedure finishes/says ok but counter stays locked. Can someone fix/clear the anti-start counter in this full flash/eeprom dump?"I'm not looking for anything for free.
Hi please Check you PMs Smile
