  • 20 Vote(s) - 3 Average
Airbag Faults Mechanical Set UP is NOT OK!
Dear MHH Members,
I have a W 204 Year 2009 I have faults in the Airbag Module. See below and picture attached
1. B0095-95 The Left front crash sensor has a malfunction. The mechanical set up is not OK. Current and Stored (if the sensor is connected)
, but if I disconnect the sensor, it gives
B0095-12 The Left front crash sensor has a malfunction. there is a short circuit to positive or an open circuit.
By this "there is a short circuit to positive or an open circuit." I understand that the wiring is good and the module is communicating with the sensor right?
Now can someone tell me what does this mean "The mechanical set up is not OK"
I replace with new sensor I have same fault. First time I see this.
Please help.
check epc,partsnumber ok?
Thanks given by: Rocinante
(11-04-2016, 09:02 PM)mb_port Wrote: check epc,partsnumber ok?
I replaced as per EPC
please anyone help me
2009 should be grey sensor not blue nor green only grey!!
(11-04-2016, 10:42 PM)ghassan.chaabo Wrote: 2009 should be grey sensor not blue nor green only grey!!
Please can you give me exact part number. I buy new as per VIN and am using EPC 07.2016
The part number is A 172 905 60 00
Here is the sensor
http://www.autoparts.com.vn/cam-bien/cam...d2029.html
If you don't have the VIN we can't check but I would guess that like stated above.. its the wrong sensors.. try 212-820-49-26
(11-05-2016, 02:21 AM)Rocinante Wrote: If you don't have the VIN we can't check but I would guess that like stated above.. its the wrong sensors.. try 212-820-49-26
Thanks I will try to find this part number 212-820-49-26 today and fit and will let you know.
The VIN you provided is NOT a 2009.. Might want to check to see if its the correct VIN.. 2009 uses the 212 part number sensors.. 2012 and up use the 172..
