[email protected]
Alientech ECM Titanium 1.61 with 26000+ Drivers
11
05-12-2018, 03:48 PM
Hello everyone,
I want to warn you that the user 'sdprovider77' cheater.
Do not waste your time and money on him.
http://mhhauto.com/Thread-SDP3-2-35
Thanks given by: catala20032004
13
11-06-2018, 03:49 AM
(09-14-2017, 08:52 PM)locke119 Wrote:(02-16-2017, 04:50 AM)Domelec Wrote: this is already here free
Hello sir,
I'm a newbie here,and search for ECM titanium software
but there is no one can download
could you please advise where can I get it?
Hello
Are you still look like for ECM Titanium ??
Let me know,
Bye
14
06-05-2020, 06:15 PM
(02-16-2017, 04:48 AM)sdprovider77 Wrote: NEW VERSION ECM TITANIUM 1.61 With 26000+ DRIVER
FULL ECM TITANIUM mit 26.106 DRIVER Feature:
1. Languages: English, Portuguese, French, Spanish, Italian, Deutsch
ecm titanium 1.61 multilangauge
2. Newest Version V6.1
3. ECM Titanium 26000+ DRIVER Supported
4. Crack version, do not need activation
5. No key needed
6. Work well on Windows XP and Windows 7
7. Checksum work 100% fine
Tips on using ECM Titanium 1.61:
This one is crack version, may not support full authorization.
Top 3 Reasons to Get ECM TITANIUM 1.61 With 26000+ DRIVER:
1. It is structured like 1.61 and there were added new Driver
2. With this software you can remap your car computer injection (ECU) for more power engine. For example if a Peugeot 307 is 90cv,
3. With this software and also using a cable (KWP or Galleto) for reading dump ECU calculator you can add more power to this vehicle
for example it will be 110Cv,this is called the chiptuning.It includes the software with11500 drivers for several models of ECU.
ECM TITANIUM 1.61 With 26000+ DRIVER Description:
ECM TITANIUM allows you to accurately and easily, autonomous and completely safe to interpret the files that are contained inside the motor controller. Through the use of Driver which true "contents" pose for reading the files contained in the control units, you can easily find the data stored in the file maps and the main rev limiter to increase the engine power, or simply the consumer to optimize.
Driver
The outstanding component of this product are its drivers the latest Generation. They offer a well-structured and functional powerful interface to create and manage projects in terms of the machined in ECM Titanium files. After the file contained in the memory of the control unit has been read, it is enough to load it. Then the software starts a search to check the presence of compatible drivers both in our personal as well as in the online database. Thanks to the studies of our developers, allows the software about to act directly on the main areas: control of air-fuel ratio, engine torque, injection system, Rail, Turbo and many other options are available.
Table View
The tabular representation of the data contained in the data read from the controller file is the easiest, fastest and most understandable way to interpret the values to increase or decrease. By clicking on the desired map, the main screen is replaced by a table that was created by crossing existing on the two axes parameters. So you can Nm, Bar and mm3, intervene directly in the physical map information, for example.
2D View
The data is converted in 2D graphs. Through this graphical representation, you can try to optimize the existing data in the engine control unit and act on only one of the maps contained in the Driver, only one byte, on any map or on a specified inside the file.
3D View
The new 3D-graphics engine allows you to interact with the data in an existing driver map. You can zoom the values directly from the graph window, rotate and edit.
Hexadecimal View
All files of the engine control unit have a hexadecimal structure. This numerical representation system is extremely common due to the direct relationship of a hexadecimal number with four binary digits in the computer science. By this hexadecimal window of ECM Titanium, you can interpret the file structure and Editing.
Checksum
It is a bit sequence that is used for checking the completeness of the data. Every time you interact with a single bit, interpreted and automatically corrects ECM Titanium the control sequence. Therefore, a successful course is guaranteed, no matter whether you work in real time or whether you need to send a file to your slave.
Package including:
1DVD x ECM TITANIUM 1.61 26000 WITH DRIVER
![[Image: ecm-titanium-161-with-26000-drivers-language.jpg]](http://www.eobdtool.co.uk/upload/pro/ecm-titanium-161-with-26000-drivers-language.jpg)
